Go Back   SailNet Community > Boat Builders Row > Other Brands
Old 03-09-2010
evenstephen is on a distinguished road
Hallberg-Rassy NAB 35 rudder question
Hello,
I am purchasing the above boat and there is apparently a vertical seam in the rudder that has leaked allowing water intrusion into the core.
Does anyone know anything about this probelm and what is involved with repairing it?
Any advice would be greatly appreciated.
Thanks,
Steve
Old 03-10-2010
klubko is on a distinguished road
I'm not 100% sure that this applies to you, but some small older HRs have rudder attachment made from bronze which looks like this:
hope that helps
Petr & Jana
s/y Janna, HR 31 Monsun
Old 03-10-2010
Sorry forgot to mention the remedy. We had exactly the same problem, water was coming from the middle of the rudder, looked like a blister. The groove around the fittings was filled with something that turned into a spongy stuff, which was very easy to remove and then we filled the groove again with thickened epoxy. (the picture is Monsun)
Petr & Jana
Old 03-10-2010
Thanks Petr. I'll post some pictures I have from a haul last year next. In the third one you can kind of see the vertical seam. It looks like it might be different than your set up.
I contacted H-R and they do not have drawings any more but suggested if there is delamination I might have to have a shop fabricate a new rudder from the old one! Yikes!
Old 03-10-2010
Photos of 1972 H-R 35 rudder
Building a Rudder Newport 30 Armchairprotest Gear & Maintenance 5 04-07-2009 01:11 PM
Emergency Steering John Kretschmer Seamanship Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Gear and Maintenance Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Cruising Articles 0 03-08-2002 07:00 PM
