My last little bit of planning - Page 6 - SailNet Community
 19Likes
post #51 of 102 Old 04-27-2013
Re: My last little bit of planning
Since all chain is really the best set up, I don't see the need to worry about stretch. Nevertheless, these need to be sized to the weight of your boat, not the necessarily size of your anchor, so you should be fine.
Naturally, the bottom conditions are going to have as much to do with holding strength as one's anchor. If set well, with proper scope in good conditions, there is no reason an anchor shouldn't hold to 25 kts and higher.
Jeanneau 54DS
Minnewaska is offline
post #52 of 102 Old 04-27-2013
Shore tie line should be a floating line.. Some use cheap polypropylene but I find its too prone to twisting and knotting itself up. We use a yellow floating braided line, not sure the name, but think its a Samson brand.
Another reason for stern tying is that the depth vs size of the cove doesn't allow you space to swing free if you use textbook scope. Btw you can pretty much forget 7:1 in most of these places.
Books are good, it's great you're preparing, but like so many of today's young parents, sometimes they read too many....
jrd22 and jackdale like this.
Faster is offline
post #53 of 102 Old 04-27-2013
Courtney the Dancer
jrd22's Avatar
Your handheld VHF isn't going to give you reliable coverage in a lot of places so you won't have current weather reports. Any way to install a fixed radio with antenna on top of the mast? Wouldn't cost much, bit of a job.
Strongly recommend the 350' stern tie line, you won't regret having it. We use cheap, sinking, crab line. Not the best but it's tough and I buy 1800' spools for prawning anyway. I think Lummi Fishing Supply (LFS, Bellingham) sells it by the foot.
Navionics for Iphone, +.
Ports and Passes, +.
Dreamspeaker cruising guides,+.
Stopping by Blakely Island Marina for a latte and ice cream cone (or draft beer) and going over the charts, anchorages, etc with me, ++.
Faster likes this.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #54 of 102 Old 04-27-2013
Now THERE'S an offer you'd be a fool to turn down! Good on ya John..
Faster is offline
post #55 of 102 Old 04-28-2013
no longer reading SailNet
Alex W's Avatar
Fisheries Supply recommended the Samson MFP float line for stern ties in BC. I ended up buying a 600' spool because that was the same as 400' purchased by the foot. I cut off some to use as a dinghy painter and will use the rest for stern ties. With my sailing club account (or it might have been the boat show deal) it ended up being around $130.
Alex W is offline
post #56 of 102 Old 04-28-2013 Thread Starter
first sailed january 2008
northoceanbeach's Avatar
Thanks! Sounds like a good deal. I did not know these BC anchorages were that small. I probably would overlook something like that.
northoceanbeach is offline
post #57 of 102 Old 04-30-2013 Thread Starter
I am getting ready to leave as we speak, though I'll still have internet alot of the time.
Two quick questions running through my head.
1. I read Washington marine parks have public mooring balls. I also looked at the way people properly tie to the balls. But this was a person in Florida. THey had two lines wrapped around the eye and tied up pretty close to the buoy. Is this how you do it up in Washington? Don't need too much line to absorb shock?
2. Do marinas usually have a place to go and tie up so you can go to shore and eat or take a shower for free?
post #58 of 102 Old 04-30-2013
jackdale's Avatar
For all mooring buoys, build a nylon bridle that runs from bow cleat to bow cleat with a full round turn around the ring. A a plumb bow, you want some distance between you and the mooring ball. With a raked bow, you can sometimes harden the mooring line to get the buoy up close without hitting the bow.
Marinas are in the business of making a profit, few will let you dock for free and have a free shower. Some will let you stay for a free lunch at their restaurant. You can anchor out and dinghy in. But even then some object to you using the facilities.
Faster likes this.
jackdale is offline
post #59 of 102 Old 04-30-2013
How we tie up to mooring buoys depends on what they're made of.. the old park buoys in BC were f/g hardshell and with a longish pennant they would eventually start banging on the hull.. we tried to tie up short to keep them under the bow overhang (not practical with today's plumb bows) The newer ones are softer and less of an issue in that regard.
Marinas will often have a day stop rate (usually 1/2 day rate) and you'll have access to their facilities that way... VERY few are likely to let you dinghy in and use the shower/laundry. In many places water is rather precious on the islands and mid summer especially they will preserve supplies for paying customers. Some marinas have restricted watering rules then too - x gals limit/no washing/etc.... Some of the marina/fuel docks that offer groceries/facilities are set up to allow you a couple of hours free while you shop (Refuge Cove comes to mind).. in other areas it's just a 'Gov't dock' and it's first come first served there but rafting is usually allowed.
Nanaimo, Ganges, Madiera Park, Comox, for a few, will allow short term tieups that way.
Faster is offline
post #60 of 102 Old 04-30-2013
Alex W's Avatar
There is a good guidebook (Home | Waggoner Cruising Guide) that covers the Puget Sound up to Alaska that answers the marina question nicely. It really can vary. The ones that aren't free for a couple of hours will normally change a small fee like 10-20 cents per foot for 3 hours of moorage. The book is really boring, but helpful and updated every year.
Get a solar shower and you can shower on the front of your boat for free (in a bathing suit at least). Just tie it to the jib halyard (clipped to the forestay) and raise it up above head level. Don't forget to have a messenger line of some sort to get it back down.
I haven't been north of the San Juans yet, but I found it easier to find good anchorages than to use mooring balls. I'd rather have a longer row into land then be stacked up super close in a mooring field.
Alex W is offline
Planning for the Break CruisingJJ Introduce Yourself 3 04-30-2010 02:58 PM
Planning the move! PalmettoSailor Chesapeake Bay 12 03-29-2010 12:50 PM
Tack Planning bacampbe Seamanship & Navigation 5 09-21-2009 08:39 PM
Planning now for retirement Kimana Introduce Yourself 2 07-02-2008 01:13 PM
Good Planning and Bad Planning John Rousmaniere Seamanship Articles 0 10-11-2001 09:00 PM
