Bilge improvment - Page 2 - SailNet Community
 2Likes
post #11 of 13 Old 08-05-2013
BMLipiec's Avatar
Re: Bilge improvment
Jay,
It is mounted under the floor just forward of the bilge access floor board, and aft of the fuel tank bilge bulkhead. It is mounted as a unit (pump and strainer) on a board and then bolted upside down in the bilge, if that makes sense. You can't really see it unless you stick your head down in the hole, but because it is removable you can drop it down to empty the strainer, mess with the fittings, etc.
The hose is tee'd into one of the drain thru-hull hoses on the port side. I forget exactly which one.
I'll take a picture of the setup next time I'm at the boat, if I don't get sidetracked.
Brian & Marya
S/V Indigo
Pacific Seacraft 34
Hull #281
BMLipiec is offline
post #12 of 13 Old 08-05-2013
manatee's Avatar
My question to all of you is whether there is logic in me epoxying over the keel bolts. Seems to me if I ever need access to them, I can (with difficulty) remove the epoxy. However, wouldn't this stop the two metals from reacting?
I used zinc chromate on my planes on the carrier, and on battery terminals on electric wheelchairs. A good paint & body or auto supply should carry the spray cans. Try not to breathe it. Forms a good airtight seal, but *way* easier than epoxy to unbolt through.
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
post #13 of 13 Old 08-16-2013
Thanks, Brian. That is most helpful.
Jay
BirdBrain333 is offline
Adding automatic bilge pump to manual bilge pump FirstCandC Gear & Maintenance 13 04-03-2013 09:59 AM
Installing automatic bilge pump in series with diaphram bilge pump... sweetdreamyamaha Gear & Maintenance 6 11-07-2009 12:36 PM
Shallow Bilge, Bilge Pump Switch labestia Gear & Maintenance 1 07-10-2009 03:40 PM
Oil in bilge Neicy Gear & Maintenance 5 12-07-2005 09:40 AM
Bilge JimMuro Provisioning 1 05-20-2004 05:56 PM
HTML code is Off
