Removing Hot Water Heater - Page 3 - SailNet Community
 6Likes
post #21 of 46 Old 07-19-2013
Re: Removing Hot Water Heater
The extra coolant tank (actually a header tank) in the locker is only there because you have the water heater. The fill point and a reservoir must be the highest point in the system. When the water heater is added, the heat exchanger in the heater is higher than the engine water jacket, hence the added header tank. If you remove the heater you can revert to using the tank on the engine. Just make sure you put the right pressure cap on the engine tank. Currently the one on the engine either has no pressure release or a higher value than the one on the tank in the locker. Hence the one in the locker relieves pressure first and vents air. If the one on the engine vents first it release coolant as it is under water. When the heater/tank is removed, put the cap from the header tank on the engine.
It is in principle a very simple job, but it's a boat so it won't be simple at all.
Good luck.
Paul
discoverer37 is offline
post #22 of 46 Old 07-19-2013
Posted last reply before reading page two of the replies. Sorry for the repetition.
Paul
post #23 of 46 Old 07-21-2013
cheoah's Avatar
expansion tank
I need to flush my coolant. I don't have a second tank above the heater so not sure how to purge the system. My wife really likes the hot water so for now ill keep it. Suboptimal above the batteries and with echo charger and Genasun in there too.
cheoah is offline
post #24 of 46 Old 07-21-2013
Cheoah,
Do you have a t-fitting with a **** for bleeding in the coolant line to the water heater? Its installed on my PSC34 in the port locker close to the water heater. I have a surge tank but I could imagine to purge the water heater through this set up.
Wolfgang
YankeePSC34 is offline
post #25 of 46 Old 07-22-2013
Cheoah,
Big brother is watching me. The **** in the last post is a Charlie Oscar Charlie Kilo aka as a technical term for an opening/closing armature.
Wolfgang
post #26 of 46 Old 07-22-2013
cheoah's Avatar
tank
Hi Wolfgang, thanks for reply. No, I just have the two hoses from engine to tank....
cheoah is offline
post #27 of 46 Old 07-26-2013
BMLipiec's Avatar
RainDog,
We recently removed our water heater as well and it was pretty straight forward as Dave says. I found a metric plug at McMaster-Carr for one port and then bought a temp sending unit at Catalinadirect.com. Catalina used the same 3jh2e on their boats and they sell a metric threaded temp sending unit that works with a Teleflex temp gauge.
Since we had to drain the system we pulled the heat exchanger and cleaned out the crud buildup, changed out most of water hoses, and replaced the exhaust riser and elbow. Maybe it is just me, but I'd swear that the water flow increased dramatically exiting the exhaust.
Incidentally, the space created from removing the hot water heater allowed me to install 4 Trojan T105s - I had to lengthen the existing battery compartment opening 2 inches.
Brian & Marya
S/V Indigo
Pacific Seacraft 34
Hull #281
BMLipiec is offline
The Following User Says Thank You to BMLipiec For This Useful Post:
RainDog (07-26-2013)
post #28 of 46 Old 07-26-2013 Thread Starter
Not Finished Yet
RainDog's Avatar
Would love to see some pictures of your battery install if you have any. That is next on our list once the HWH is gone.
RainDog is offline
post #29 of 46 Old 07-26-2013
BMLipiec's Avatar
RainDog,
Here are a couple of photos before I finished routing and cleaning up the wire runs.
I have more detail on our website (still under construction) at Electrical System - Cruising Indigo
Brian & Marya
S/V Indigo
Pacific Seacraft 34
Hull #281
BMLipiec is offline
post #30 of 46 Old 07-26-2013 Thread Starter
Not Finished Yet
RainDog's Avatar
Wow. Great write up. Thanks for taking the time to do this. I am going to pretty much copy exactly what you did. Exactly what I have been looking for. Where did you install your charger? I hate to put it with the batteries or the engine, but also hate my other options. Still trying to decide.
RainDog is offline
LPG water heater WilliamWalker Gear & Maintenance 17 07-21-2011 12:34 AM
need hot water heater twisted23 Gear & Maintenance 13 01-15-2011 12:57 AM
cs 30 water heater timmorgan CS Yachts 1 07-21-2009 07:01 AM
new water heater ralphmacey Announcements and Suggestions Box 6 05-26-2008 02:19 PM
Connecting raw water cooling to water heater Northeaster Gear & Maintenance 18 04-28-2007 07:11 PM
HTML code is Off
