Removing Hot Water Heater - Page 4 - SailNet Community
 6Likes
post #31 of 46 Old 07-27-2013
BMLipiec's Avatar
Re: Removing Hot Water Heater
RainDog,
I struggled with that one too. There just isn't a good spot. I will probably install it in the same compartment. Although i have thought about putting it in the engine room too, because it will keep the cable run short and you will probably never run the charger and the engine at the same time so heat shouldn't be a problem. I don't plan on using the charger much though. With the solar panels currently installed (100 watts) I haven't needed a 110v charger as they keep both battery banks topped up.
Brian & Marya
S/V Indigo
Pacific Seacraft 34
Hull #281
BMLipiec is offline
post #32 of 46 Old 08-14-2013
no longer reading SailNet
Alex W's Avatar
I'm back on this project now that I'm back from cruising.
I have a Yanmar 2GM20F. I inspected my system last night and figured out what I'd need to do. Is the proper threading for the plugs documented anywhere? That seems like a cleaner solution than looping back the hose. The Yanmar 2GM20F workshop manual didn't list the threading, and I'm assuming it is metric and so not easy to find locally.
Alex W is offline
post #33 of 46 Old 08-14-2013
DaveMancini's Avatar
Hi Alex,
You're right, every time I look at that loop, I want to plug it. Just lazy I guess. I think those are 3/8 pipe thread plugs, not metric. I believe the Yanmar part number on a 2GM20F is 23871-030000 (same for both), but a Yanmar dealer can confirm.
Go here for a parts breakdown: http://tehstar.ru/assets/files/manuals/2GM20.pdf
It's on figure 25.
Dave Mancini
DaveMancini is offline
post #34 of 46 Old 08-14-2013
BMLipiec's Avatar
I believe everything on the Yanmar is metric. I bought a 3/8 bpt metric threaded plug from McMaster-Carr, but you might be able to find something at an auto parts store that carries parts for Japanese vehicles.
Brian & Marya
S/V Indigo
Pacific Seacraft 34
Hull #281
BMLipiec is offline
post #35 of 46 Old 08-15-2013
Brian,
You are correct, it is "metric" or actually Japanese Industrial Standard JIS B 0203, which is identical to British Standard Pipe or DIN which the Japanese adopted some time back. That's why the drawings indicate "3/8" because the thread pitch is actually measured in inches. But it is not the same as US NPT pipe thread in either pitch or taper angle (I was wrong). Very confusing but the right plugs are readily available. The Yanmar numbers are correct, but may be more expensive than from other sources like McMaster Carr (I love those guys).
Good catch.
Dave
post #36 of 46 Old 08-15-2013
Alex W's Avatar
Thanks. There are many Yanmar parts suppliers around here, I'll probably just try them first. If not Tacoma Screw may have them.
I'll add that parts list PDF to my other pile of Yanmar stuff, it is a handy reference.
Alex W is offline
post #37 of 46 Old 09-26-2013
This month I removed the water heater, the surge tank and all coolant hoses. I was happy to get rid of the stinking monster. I installed a short cut in the potable water hoses. I also plugged the two ports in the coolant pump housing with 3/8” plugs I got from the guys in my local Yanmar shop. New engines come with the plugs installed. They take them out when installing a water heater . I still have the surge tank and the bleeding valve available. If somebody wants them please contact me with a private message.
Presently I am installing 4 golf cart batteries following Brian’s (S/V Indigo) solution. I am still in awe that he figured that out. Brian, big thank you for your help.
Earlier this month I installed two 85W solar panels, and, being a fan of proven solutions, I followed Dave’s (S/V Swan) design for the support framing. All worked very well and me and my dock neighbors like the easy looking structure. Dave, big thank you for your help too.
Finally a thank you to Raindog because if you would not have started this thread, I would still be trying to figure out a solution to my energy improvement needs.
Wolfgang
PSC34 Yankee #274
Rock Hall, MD
YankeePSC34 is offline
post #38 of 46 Old 09-29-2013
Maine Dub
34crealock's Avatar
I'm not sure I am of the same mindset. After a few days of 25knot winds, quartering seas, lots of salt spray , 50 degree days and 40 degree nights I really enjoyed a steaming hot shower. I think I'll suffer with the hot water heater for a while longer since it was great to have on the 6 day Maine cruise I completed yesterday.
Al Pickering
PSC 34 #286
Coorie Doon
34crealock is offline
post #39 of 46 Old 09-29-2013
Not having a water heater is my excuse for sailing in warmer climes.
oceangirl and 34crealock like this.
post #40 of 46 Old 09-29-2013
Maine Dub
34crealock's Avatar
Good Dave, the inverse( staying in Maine) being my reason to retain the water heater.
DaveMancini and YankeePSC34 like this.
Al Pickering
PSC 34 #286
Coorie Doon
LPG water heater WilliamWalker Gear & Maintenance 17 07-20-2011 11:34 PM
need hot water heater twisted23 Gear & Maintenance 13 01-14-2011 11:57 PM
cs 30 water heater timmorgan CS Yachts 1 07-21-2009 06:01 AM
new water heater ralphmacey Announcements and Suggestions Box 6 05-26-2008 01:19 PM
Connecting raw water cooling to water heater Northeaster Gear & Maintenance 18 04-28-2007 06:11 PM
HTML code is Off
