Replacing engine mounts - Page 3 - SailNet Community
 2Likes
post #21 of 26 Old 08-27-2013 Thread Starter
Re: Replacing engine mounts
A Canadian yacht had to be abandoned and the skipper rescued off the Great Barrier reef last year, when his Yanmar mounts all broke, and his loose engine bashed a hole in his hull. I have heard other stories about Yanmars breaking loose from all their mounts simultaneously, leaving the engine rolling dangerously in the bilge. They have nothing but rubber holding your engine in. You would be wiser to go for Perko mounts, which are not dependent on rubber alone for holding your engine in. If you have new Yanmar mounts, a bit of chain to stop your engine from breaking loose completely would be a good safety factor.
I agree that Yanmar mounts have no captive design against lateral (rolling) or uplift (capsize) forces. Fortunately the design does allow a quick and simple captive securing, i.e. with a chain.
YankeePSC34 is offline
post #22 of 26 Old 08-27-2013
BMLipiec's Avatar
I found this on Yanmarhelp.com at ENGINE MOUNTS in regards to safety wiring the mounts for offshore use.
Brian & Marya
S/V Indigo
Pacific Seacraft 34
Hull #281
BMLipiec is offline
The Following User Says Thank You to BMLipiec For This Useful Post:
34crealock (09-05-2013)
post #23 of 26 Old 08-28-2013
Location: The house is in Kingsport, TN. Boats are on Watauga Lake and in New Bern, NC
I have had one mount fail under my 3HM35F Yanmar (front port). It was not the rubber to metal bond that failed, but rather the engine mounting bolt which cracked through just above the point where it joined the upper metal plate. It made a ticking noise when the engine idled. The surveyor heard it before we bought the boat, but he could not locate the source. We found it 6 months later. I replaced all four. Later when we had the engine rebuilt, I replaced all four mounts again with no indication that anything was wrong with the existing mounts.
Bill Murdoch
1988 PSC 34
Irish Eyes
wsmurdoch is offline
post #24 of 26 Old 09-03-2013
Bill, I had the same mounting bolt break at the same point. I have an engine driven refrigeration compressor on a bracket that attaches to that motor mount. Do you also?
johnharch is offline
post #25 of 26 Old 09-04-2013
The forward port engine mount was broken when we bought Irish Eyes. At that time the engine drive refrigeration compressor was missing. (The hoses and clutch wire had been cut and hidden.) The compressor had previously been installed on the starboard side of the engine about even with the 3HM35F injection pump on brackets attached to the injection pump bolts. In that location it rubbed on the fuel fill line and blocked access to the dip stick, the small engine fuel filter, and the priming lever on the engine fuel pump. When I reinstalled the compressor a year or so later, I made a new bracket and mounted the compressor above the engine and to port just above the spot where the Yanmar factory alternator mounting bolt goes.
Bill Murdoch
1988 PSC 34
Irish Eyes
post #26 of 26 Old 09-04-2013
My compressor is also on the port side. the bracket is really strong, but is mounted to everything. Two of the water pump bolts, one head bolt, the forward port motor mount and two bolts into what appears to be the where the original rear motor mounts were on the engine.
Tags
engine mounts , yanmar 3jh2e
Replacing Yanmar Motor Mounts - anyone with 3rd party success? Beersmith Diesel 1 05-17-2012 04:32 PM
Engine mounts GaiaOrion Gear & Maintenance 6 06-05-2011 12:38 AM
Engine Mounts quanyin Pacific Seacraft 0 05-03-2011 12:00 PM
PYI Engine Mounts and PSS cvsheppard Gear & Maintenance 2 08-08-2009 10:11 PM
Need Engine mounts.. RDV Gear & Maintenance 2 09-05-2006 02:15 PM
HTML code is Off
