Fasteners holding down the cockpit sole - SailNet Community
post #1 of 11 Old 09-10-2013 Thread Starter
Hi,
One of the things I want to do in my tiller steered 37 is to make it so that I can get the cockpit sole up easily to access the engine. I know later boats have a two part floor - can someone tell me how is the removable section held down, please? Screws, catches?
I don't want to put something in that will hurt feet,etc. my bad back is making going through the lazarette too hard.
thanks in advance,
John
Sent from my iPad using Tapatalk - now Free
johnbanfield is offline
post #2 of 11 Old 09-10-2013
Not Finished Yet
RainDog's Avatar
Re: Fasteners holding down the cockpit sole
The floor has a flange that the lid sits on. On each corner there is a bolt bedded in the floor the lid drops down over. See pictures below for examples.
RainDog is offline
The Following User Says Thank You to RainDog For This Useful Post:
johnbanfield (09-10-2013)
post #3 of 11 Old 09-10-2013 Thread Starter
Looks perfect, thanks. The large size of the nuts should stop hurnint feet, which was what I didn't understand..
If I can't find these or similar locally I'll ask PSC.
Cheers,
John
post #4 of 11 Old 09-11-2013
John,
What hull no. is your boat and is the floor one piece or two? On older 37's with factory tillers and one piece cockpit soles there are eight coach bolts with nuts and washers under the flange accessible by climbing thru the lazarette a real PIA for anyone larger than a child or small woman.Newer boats are equipped with the knurled knobs shown in the picture.
Good luck,
Dianne and Chuck Burke S/V NiftyNickers C37 #139
niftynickers is offline
post #5 of 11 Old 09-11-2013 Thread Starter
Hi,
I can't remember the hull number but she is a 1981, with the one piece floor and coach bolts.
Another solution might be those flat stainless hatch latches with the flip-up handles you twist, but I think I'd need about $800 worth of them!
Cheers,
John
post #6 of 11 Old 09-11-2013
oceangirl's Avatar
Yes, my 25PSC that I owned in my 20s, had about 30 or so bolts that held a large hatch. PITA to get off but the access was great! Full complete engine access and I could sit on my tranny to work on the stuffing box .
Mrs. Rain Dog
PS
Those are not pictures of Rain Dogs cockpit, I couldn't find any so we just pulled some up off the net, one is of a 31 the other a 34.
~~Ocean Girl~~
~~Mrs. Rain Dog~~
1989 Pacific Seacraft Crealock 34 Hull# 142
oceangirl is offline
post #7 of 11 Old 09-12-2013
My husband cut starboard into which he installed T-nuts and mounted below the lower lip aligning the T-nuts with the existing holes, which he enlarged. 5/16" oval head screws with a finish washer under which he placed a rubber gasket, now fasten from above. He seems much happier and there is less cussing from the cockpit during the floor raising process. Raising the floor is now a simple 10 min job!
Ellen
Shibumi
C37 #7
ellenwhite2 is offline
post #8 of 11 Old 09-12-2013
My cockpit sole is the same as yours and after several years of wiggling thru the lazarette I installed two 6" Beckson access ports in the sole thru which I can insert my arm with a socket wrench to access the nuts below.The ports are each placed in the middle of a quartet of bolts and the forward port has a clear insert so that daylight shines on the engine (an added bonus).This also provides two handholds for handling the awkward sole.Another added bonus is the ability to see the rear of the engine and trans without lifting the sole.
Good luck,
post #9 of 11 Old 09-12-2013
Handholds would be darn nice!
post #10 of 11 Old 09-13-2013 Thread Starter
Great, thanks for the ideas, everyone.
Cracked Cockpit Sole jetdrvr393 Gear & Maintenance 15 04-14-2012 12:29 AM
Cockpit sole repair 1965Columbia31 Gear & Maintenance 6 06-05-2011 06:18 PM
S2 cockpit sole core material timangiel S2 3 03-10-2011 03:47 PM
new core for cockpit sole Grcesq Gear & Maintenance 10 11-17-2009 05:18 PM
Is the cockpit sole cored? timangiel Gear & Maintenance 10 05-11-2007 10:32 AM
HTML code is Off
