Cockpit shower placement in psc 37 - SailNet Community
post #1 of 5 Old 10-17-2013 Thread Starter
Hi all,
We are considering fitting a cockpit shower. Can you please tell me where you normally put them?
Thanks, John.
Cheers,
John and Alison
Sv Liberty
1981 PSC 37
johnbanfield is offline
post #2 of 5 Old 10-17-2013
BMLipiec's Avatar
Re: Cockpit shower placement in psc 37
John,
On our 34 the cockpit shower head is installed in the recessed box (aft end or left side as you look at it) under the cockpit winches. When stowed all you can see is the plastic cover. I have no complaints and it has worked very well for us.
Brian & Marya
S/V Indigo
Pacific Seacraft 34
Hull #281
BMLipiec is offline
post #3 of 5 Old 10-17-2013
Maine Dub
34crealock's Avatar
Is the deep lazarette on the Port side of the 37 also. On the 34 that is where the hot and cold water is as well as electrical supply so it would be the logical side to install it.
Al Pickering
PSC 34 #286
Coorie Doon
34crealock is offline
post #4 of 5 Old 11-09-2013
If you want a simple cockpit shower that requires little modification, consider what we did.
We hook a threaded coupling to the pressure faucet in the galley sink to which a small diameter hose is attached. That hose has a shower head on the cockpit end. It is working great for us.
Bob Steneck
PSC 34
Christmas Cove, Maine
Antilles 2013 - 2014
steneck is offline
post #5 of 5 Old 11-20-2013
WINDFLOWER-PSC37
Wind Flower's cockpit shower was installed on the starboard side of the cockpit beside the Whale pump. Works well and allows for fresh water rinse while on the ladder.
karlinD is offline
Shower Pan jarod Gear & Maintenance 11 11-19-2012 10:49 PM
Center Cockpit Versus Aft Cockpit BlueWaterBlair General Discussion (sailing related) 58 03-19-2012 12:35 PM
PSC cockpit shower replace Drifting Pacific Seacraft 4 09-30-2009 04:10 PM
A hot shower! johnamross General Discussion (sailing related) 5 04-12-2003 07:50 AM
Shower Set Up SailNet Buying a Boat Articles 0 07-07-2001 08:00 PM
HTML code is Off
