headliner - SailNet Community
post #1 of 3 Old 10-20-2013 Thread Starter
BMLipiec's Avatar
headliner
Has anybody taken down the head liner completely on a 34/37? We just installed some mast pulpits on Indigo and we had to pull the headliner staples out near the outboard edges to be able to drill through the deck and bolt it in. It was a real pain to get the headliner staples out but I'm afraid it will be much worse getting it back up.
There has to be a trick to getting the headliner stapled back in place tight without wrinkles. Someone told me to try and heat it with a hair drier to stretch it out - and should tighten up after stapling as it cools back down. Any special tools that would make it easier?
Since I have it part way down, I'm considering going the rest of the way (one side at a time) in order to re-bed the deck hardware. Nothing leaks now, but it's 20 year old sealant and it seems like a good time to do it.
Brian & Marya
S/V Indigo
Pacific Seacraft 34
Hull #281
BMLipiec is offline
post #2 of 3 Old 01-14-2014
Re: headliner
Brian
A few years back I pulled the headliner off the boat. We had bought the boat new and the mast pulpits were not included in the original order, but were added prior to the boat leaving the Fullerton facility. Apparently they were installed after the headliner and the amount of sealant used was minimal which resulted in leaks when the boat was worked hard.
The boat was worked hard doing the Baja Bash north and as a result the zippers were completely corroded, I needed to pull and reseat the mast pulpits and with the headliner off reseated most of the deck hardware.
Took awhile to find someone to replace the headliner. But utimately Hoffman Foam of San Diego did a beautiful job. They also did an excellent job on the new interior cushions that were done year.
I would suggest giving Memo of Hoffman Foam a call and see if he can help with reinstalling the headliner in your boat.
Marc Hall
Crazy Fish - Maintaining, Upgrading and Sailing a Crealock 37
MarcHall is offline
post #3 of 3 Old 01-14-2014 Thread Starter
BMLipiec's Avatar
Re: headliner
Thanks Marc,
I appreciate the help, and I'll give them a call.
I see that the PSC factory is now doing panel and batten overheads which looks much better IMO and would make getting to the bolt heads so much easier. However, I don't think that will fit in my budget or timeline any time soon.
Brian & Marya
S/V Indigo
Pacific Seacraft 34
Hull #281
BMLipiec is offline
Headliner Melrna Hunter 15 05-12-2010 05:17 PM
P30 Headliner nickmerc P30 1 10-18-2009 09:39 AM
Headliner Out Islander30Bahama Sailboat Design and Construction 1 07-16-2008 03:05 AM
Headliner on S38 MK II jimkevern Sabre 0 09-24-2007 07:52 PM
How do I fix this headliner? bestfriend Gear & Maintenance 12 07-23-2007 07:28 PM
HTML code is Off
