31 genoa car - SailNet Community
post #1 of 7 Old 11-20-2013 Thread Starter
31 genoa car
The pin (plunger?) for the genoa car on my '87 Pacific Seacraft is broken. Does anyone know a good source for a replacement?
I believe the car is a Lewmar but web searches so far are confusing. The track is 1 1/4 inches wide. (If it is Lewmar then it is probably more accurately 32 mm).
If I can't find the pin then what would be the suggestions for a car to use on 32 mm or 1.25 inch track? I don't race (unless there is a boat going the same way) but I do like to get what I can out of the sails.
John
Watermark
PSC 31 #28
wmjr is offline
post #2 of 7 Old 11-20-2013
Re: 31 genoa car
If you know what you have you can probably get a rebuild kit. The pull pin type typically are pretty simple, with just a plunger and spring.
If you can't figure it out, SCHAEFER Stainless-Steel Genoa Slides at West Marine has a universal car for about $70.
Greg
Stumble is online now
post #3 of 7 Old 11-20-2013 Thread Starter
Re: 31 genoa car
Stumble,
Thanks, I have not found any rebuild kit yet. It is really old. Maybe a trip down to Minney's in Costa Mesa is in order. The slide looks to me like it would be very difficult to adjust with any pressure at all on it.
It would be nice to find a plunger that fit. I was hoping a 31 owner might have run in to the problem already. The old plunger button was cracked. All it does is push down the spring in the plunger. Hard shape to recreate though.
wmjr
wmjr is offline
post #4 of 7 Old 11-20-2013
Re: 31 genoa car
These old parts just don't normally have rebuild kits. Small manufacturers often went out of business, and no one wanted their old catalog.
If you are worried about adjusting under load I would really recommend looking at moving jib cars. They are a bit more expensive, but much easier to play.
Greg
post #5 of 7 Old 11-21-2013 Thread Starter
Re: 31 genoa car
Tempting, but all the extra lines and blocks sound a little too much. It is usually just two or three adjustments per day. My sailing is not that advanced and, as I said, I don't race.
I was hoping (wishing?) that there was a more simple solution. A super slippery car maybe with a clever little easy to release pin.
Thanks,
wmjr
wmjr is offline
post #6 of 7 Old 11-22-2013
Re: 31 genoa car
John,
I recently replaced the genoa cars on Journey (PSC31 #29) with Garhauer cars. They are LLC-2 and cost something like $65 each. The quality is great for the price.
Adam
PSC 31 Journey
adamowens is offline
post #7 of 7 Old 11-23-2013 Thread Starter
Re: 31 genoa car
Adam,
Thanks. I have a pin coming from someone who has a spare but the button? for the pin on the other side is looking brittle as well. I will look at the Garhauers very closely.
Appreciate it,
John
wmjr is offline
Where can I get this Genoa Car pin? Tanley Gear & Maintenance 16 11-25-2013 03:27 PM
Genoa Traveler Car with Cleat? Dave_E Gear & Maintenance 13 09-17-2013 03:43 PM
CS 34 genoa car track padean CS Yachts 1 01-04-2010 11:32 AM
Genoa Car - Bene 320 spankerdog Beneteau 2 08-19-2009 12:02 PM
Question about Genoa Car adjustment skrap1r0n Learning to Sail 47 04-20-2007 05:15 AM
HTML code is Off
