Galvanic Isolator - Page 2 - SailNet Community
post #11 of 14 Old 01-14-2014
Re: Galvanic Isolator
Recently (3 weeks ago) installed a galvanic isolator on Crazy Fish.
Mounted it outboard on the rear quarterberth bulkhead a short run from the AC plug. Probably above the level of the original headliner but the quarterberth headliner was removed many years ago and never reinstalled.
One of the simpliest installations of devices on the boat.
Marc Hall
Crazy Fish - Maintaining, Upgrading and Sailing a Crealock 37
MarcHall is offline
post #12 of 14 Old 01-15-2014 Thread Starter
Marc,
Thanks, I ended up putting the Galvanic Isolator in the wet locker aft of the head mounted just below the new charger. With Thumper's help from Pacific Seacraft I found access to the shore power cable very close to the inlet.
Next challenge is to link the AC ground to the DC ground.
John
Watermark
PCS 31
wmjr is offline
post #13 of 14 Old 01-15-2014
Maine Sail's Avatar
Originally Posted by wmjr View Post
Marc,
John
Watermark
PCS 31
Just check continuity behind the panel. Put one lead to AC ground and the other to the DC bus... Most boats built in the last 20-30 years are wired with the AC/DC bond, though a few brands were not....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #14 of 14 Old 01-16-2014 Thread Starter
"Just check continuity behind the panel. Put one lead to AC ground and the other to the DC bus... "
I checked for continuity from AC ground to DC bus behind the panel. No joy.
Here is my plan:
1. temporary fix - Connect a 10awg green wire from ac ground at panel to dc bus at panel 12 inches away.
2. March to the future - Having read every post about ground(ing) on every site plus every compass marine diagram and picture plus Calder I intend to clean up the battery area by installing positive and negative bus bars with one of them becoming the new dc negative bar and a second bar (connected to that one) to terminate the non-conducting grounding wires and then on to engine ground. No fuses now at battery so that project happens at the same time.
Here is what is stopping me:
A) The all neg to one place law.
There are now two negative wires going to the engine (three if you count the alternator which is a 2G wire from alternator to battery 1 negative post.)
1) One 4G wire from bat 1 to bolt where transmission bolts to engine.
2) One 4G wire from DC neg at panel to second bolt where transmission bolts to engine. These bolts are 4 inches apart. The DC neg wire would be brutally difficult to re-run to the proposed new neg bus bar in battery compartment.
Are two bolts four inches apart on the engine one place or two?
Sorry for the consulting fee worthy length but this stuff has a lot of pitfalls.
John
Watermark
wmjr is offline
How to make your own Galvanic Isolator for under $20 yandina Gear & Maintenance 14 12-13-2012 12:14 PM
Wiring a galvanic isolator Minnewaska Gear & Maintenance 6 05-22-2011 06:25 AM
Galvanic Isolator Question Allanbc Electrical Systems 9 03-16-2011 07:51 AM
Galvanic isolator Minnewaska Gear & Maintenance 1 09-14-2010 12:57 PM
Galvanic Isolator for Crealock 34 HankJordan Pacific Seacraft 1 07-20-2008 07:58 AM
HTML code is Off
