PSC 37 staysail sheet rigging options? - Page 2 - SailNet Community
 2Likes
post #11 of 16 Old 06-27-2014
Maine Dub
34crealock's Avatar
Re: PSC 37 staysail sheet rigging options?
Grant, it is the same on my 34, if I run the sheets out side the shroud then I can't go to windward without rubbing, if I run them inside and then ease the sheets they rub inside. I put plastic snap on covers over the shroud and just let them rub and there is no chaffing showing after 20 hours of use. There must be a rigging solution and I expect someone will inform us.
Al Pickering
PSC 34 #286
Coorie Doon
34crealock is offline
The Following User Says Thank You to 34crealock For This Useful Post:
granche1 (06-27-2014)
post #12 of 16 Old 06-29-2014
SV Skalliwag #141
brokesailor's Avatar
Could this "staysail" actually be a yankee? I don't think my staysil extends that far back.
brokesailor is offline
post #13 of 16 Old 07-02-2014 Thread Starter
The sail came out of a bag marked "Staysail" and is a hank on. Since I have a roller on the front, there would be no way to put it up there without taking down the foil. I do have another sail that is marked "small staysail" but I have yet to try it out. Should a staysail not come back past the mast?
Grant
granche1 is offline
post #14 of 16 Old 07-02-2014
SV Skalliwag #141
Grant I'll rig mine up this weekend and post pictures.
post #15 of 16 Old 07-03-2014
Location: The house is in Kingsport, TN. Boats are on Watauga Lake and in New Bern, NC
Staysail dimensinons are in an earlier posting. (Google is your friend.)
Staysail measurements for a 37
Bill Murdoch
wsmurdoch is offline
post #16 of 16 Old 07-05-2014
Hi,
I added a staysail setup a couple of years ago. Not saying it is the best way, but it is working for us.
I added two tracks on the cabin top , fore and aft not angled, mostly because it was easier to install.
I didn't want to add another line to the 8 that are already running to the stbd halyard winch, so I led the stbd staysail across the cabin top to the port side with two cheek blocks.
I installed a nice shiny new self tailing winch to port to handle them both. Works really well when tacking as you throw the old sheet off and grab the other without moving.
Our staysail is on a roller - when we upgraded our main furler we moved the old one back.
I got the sail built after figuring out the track length and position so that it would work with all the hardware. It was still almost too long in the luff because I changed my mast rake, so I would recommend taking actual measurements (twice) to give the sailmaker and ask them to be a little conservative.
I just went with a cross cut from Lee sails in Hong Kong. Happy with the sail.
Cheers,
John
Cheers,
John and Alison
Sv Liberty
1981 PSC 37
johnbanfield is offline
PSC 37 How many have done away with staysail? sailak Pacific Seacraft 15 10-05-2012 09:11 PM
staysail sheet leads on Gulfstar 39 bonfyr Gear & Maintenance 0 06-13-2011 11:23 AM
Staysail rigging terryjoe Sailboat Design and Construction 10 12-13-2010 04:44 PM
Staysail rigging Acadia Gear & Maintenance 5 10-31-2010 08:01 PM
Staysail sheet lead-block tracks dhornsey Gear & Maintenance 19 01-15-2009 07:27 PM
HTML code is Off
