PSC 37 staysail sheet rigging options? - SailNet Community
 2Likes
post #1 of 16 Old 05-26-2014 Thread Starter
Hi all. I just sailed my 1986 37 from Ecuador to Nuka Hiva. I used my 135 genoa or the asymmetric for the entire crossing. Throughout my trip south and west, I have used my staysail very little, primarily because I am not sure how to properly rig the sheets. With the guaranteed stormy passage to New Zealand looming ahead I want to get this sorted out right.
Perhaps someone can walk me through where the sheets lead?
I have 2 t-tracks on top of my cabintop that have small shafer lead cars but I am not sure where to lead the sheets from there. There are some holes that lead under the dodger into a couple of rope clutches.
The starboard side clutch is full with the mainsheet, main halyard and 2 reefing lines. The fifth outboard most hole leads to a camlock type block with no known function.
On the port side, there are 2 holes under the dodger that lead to a 3 line rope clutch. This clutch is unused and one of the labels says spinnaker on it though I do not use it for my asymmetric. I have one non self-tailing winch on each side of the companionway.
What I normally do is put the portside staysail sheet through the rope clutch and the starboard side through the empty camlock block. Since it is such a pain to thread the sheets through the holes and the rope clutch, I leave the sheets rigged but since I rarely have occasion to use the stay-sail, they are just tied at the base of the mast where they are baking in the sun. When I want to use the sail, I have to go untie them and then retie them to the clew.
I dont like this setup with the sheets being led trough a rope clutch and a cam block. How do you guys do it?
Grant Gardner
s/v Viandante
granche1 is offline
post #2 of 16 Old 05-26-2014
SV Skalliwag #141
brokesailor's Avatar
Re: PSC 37 staysail sheet rigging options?
I don't lead mine thru any clutches. Just lead it thru the Schaefer lead cars straight back to the winch. On my boat you have a fair lead to the STBD most winch on the cabin top. ( you have 2 winches on STBD and one on port?). On the port side I did not have a fair lead so the yard put a fair lead on the structure that the traveler sits on the Port outboard. From there straight to the winch.
If not actively using the staysail just leave the whole mess in its bag on the inner forestay. If you think you will need it deploy it with the headsail. When the wind pipes up roll up the headsail and your left with the main and staysail in service.
brokesailor is offline
The Following User Says Thank You to brokesailor For This Useful Post:
granche1 (05-26-2014)
post #3 of 16 Old 05-26-2014 Thread Starter
Thank you Brokesailor. I only have one winch on each side and no fair lead that does not go through a clutch. Not ideal.
Does anyone have a similar setup to the one I have described? If so, how do you work it?
granche1 is offline
post #4 of 16 Old 05-28-2014
It sounds like you are having much fun already.
But you haven't taken control of your boat yet. The previous owners always do random stuff, and it is up to each of us to rig something we understand and we are confident in. I'm glad to hear you are now busy with this task. In the case of my 1987 PSC 37, none of the previous owners had completed the cutter rig setup, and I bought it only last year... after 26 years of the baby stay and running backstays existing (pretty well uselessly). It had no tracks for the staysail sheets, no entry through the dodger, no winches, and no cleats for the sheets. The previous owners liked it as a sloop, apparently. Your previous owners did something to keep themselves happy, but you don't have to figure out their systems; you have to have one that fits your own purposes.
After much thought and consulting with PSC I have decided not to install the staysail tracks, seeing as how they would involve 16 new holes in the roof and introduce new clutter to the walking space. Instead I have put in a pair of barber-haulers. The granny bars (mast pulpit) do not allow for any athwartship control of the sheets anyway, so the only control action on this boat model is downwards. My barber-haulers simply connect to the granny bars. From there, the sheets sneak past the dodger by going snug up against the inboard edge of the two humps that the traveler sits on. Immediately aft of that is a rope clutch leading to a special winch. Since it is too cramped under the dodger to rotate a conventional winch handle full circle, I have designed an alternate mechanism that operates more easily. Whatever your current situation is, I recommend that you complete this sort of design and construction before you leave Ecuador. Alas, this advice appears to be too late.
Your boat seems to have a lot of stuff brought back to the cockpit. That decision is one that often gets rethought and revoked or rejiggered. The previous owners may well have left you a setup that no longer makes total sense, so don't waste too much of your brain trying to figure out how it is supposed to be used.
capnJudd is offline
post #5 of 16 Old 05-29-2014
Grant,
Your set-up sounds very much like mine on Nifty Nickers.My staysails sheets also lead thru the cabin top blocks and to the clutches near the winches under the dodger.Since the staysail sheets have very low loads they are easily controled by the rope cluchches by the roof top winches.I have found that t he staysail is far more reliable off-shore than a genoa especiailly at night when sailing short-handed.Then again I'm old and not in a big hurry.
Di and Chuck S/V NiftyNickers C37 #139
brokesailor likes this.
niftynickers is offline
The Following User Says Thank You to niftynickers For This Useful Post:
granche1 (06-27-2014)
post #6 of 16 Old 05-30-2014
SV Skalliwag #141
Nifty: did you ever sell Nickers or did you have her repaired?
post #7 of 16 Old 05-31-2014
Hi Broke,
We still own NiftyNickers and all the storm damage has been repaired.She no longer has a radar arch or solar panels but she is back to seagoing shape and we are sailing and enjoying her.
fair winds,
Dianne and Chuck Burke
C37 #139
post #8 of 16 Old 06-01-2014
SV Skalliwag #141
Nifty: that is great news! So happy for you!!!!!!!!!!!!!!
post #9 of 16 Old 06-01-2014
Location: The house is in Kingsport, TN. Boats are on Watauga Lake and in New Bern, NC
There is a jpeg of the PSC 37 Rigging Guide in a thread at the other Pacific Seacraft forum. It might be of use to you.
pacificseacraftowners.org ? View topic - Documents and Data Thread
Bill Murdoch
1988 PSC 34
Irish Eyes
wsmurdoch is offline
The Following User Says Thank You to wsmurdoch For This Useful Post:
post #10 of 16 Old 06-27-2014 Thread Starter
Thank you all for the help on this. I rigged up the stay sail and used it on the crossing from the marquesas to fakarava. I found that almost any way that I led or adjusted the sail and cabin top blocks, the sheets or staysail would rub on the shrouds. The sail is practically new so im not sure it was ever used. Is this sail supposed to more than fill the fore-triangle? The clew extends a couple feet behind the mast. It looked cool with the staysail and genoa both flying but I did not like the chaffing. Any hints on how to run these sheets and avoid hitting the shrouds?
Thanks for thinking and explaining'
Grant
s/v Viandante
granche1 is offline
PSC 37 How many have done away with staysail? sailak Pacific Seacraft 15 10-05-2012 09:11 PM
staysail sheet leads on Gulfstar 39 bonfyr Gear & Maintenance 0 06-13-2011 11:23 AM
Staysail rigging terryjoe Sailboat Design and Construction 10 12-13-2010 04:44 PM
Staysail rigging Acadia Gear & Maintenance 5 10-31-2010 08:01 PM
Staysail sheet lead-block tracks dhornsey Gear & Maintenance 19 01-15-2009 07:27 PM
HTML code is Off
