leak from rudder stock - SailNet Community
 2Likes
post #1 of 25 Old 05-26-2014 Thread Starter
jvlassak's Avatar
Hi - I just got back from a fun two-day sail and noticed that there is some water leaking from the rudder stock of our PSC 34. It seems to leak only when we're underway, not so much when we're moored. The bilge pump can easily keep up with the water coming in, but still it's a bit more than I'd like. I assume it is the stuffing box for the rudder stock that may need adjustment - any recommendations on how to do this? Access is just so difficult. Any and all suggestions welcome!
1995 Pacific Seacraft 34
Iphigenia
jvlassak is online now
post #2 of 25 Old 06-07-2014 Thread Starter
jvlassak's Avatar
Re: leak from rudder stock
Does any PCS 34 owner know if it is possible to replace the stuffing in the rudder stock stuffing box without hauling the boat? The stuffing box is not leaking at the mooring, but when sailing fast or motoring it is leaking more than I'd like - thanks - Joost
Iphigenia
post #3 of 25 Old 06-09-2014
We have replaced the hose clamps and it was not easy to reach, but I guess you could replace the packing in the stuffing box without hauling you boat. Have you asked the PSC factor?
Pegasus34 is offline
post #4 of 25 Old 06-09-2014
Not Finished Yet
RainDog's Avatar
also make sure it is really the rudder post. At least two owners I know of have found a hole at the bottom of the propane locker. When the stern squats enough for the drain holes to go under water, this hole will start leaking into the boat. It looks a lot like a rudder post leak. Obviously this is something you want to fix ASAP.
I have the same rudder post leak. Replacing the hose clamps did nothing for it. Hoping you figure it out for me
zeehag likes this.
RainDog is offline
post #5 of 25 Old 06-09-2014 Thread Starter
jvlassak's Avatar
Thanks. I haven't yet, but will do so today. I think access is the biggest problem. I've tried many times to get in there, but I'm just too big (or not flexible enough ). The hose and clamps look fine.
Iphigenia
post #6 of 25 Old 06-09-2014
Not Finished Yet
RainDog's Avatar
I have hired three professionals to go fix it. All three came to the boat, took one look at it, and declined to go back there
Luckily one of our forum members volunteered to go back and replace the hose clamps for me.
See also: Rudder Post Access Hatch
RainDog is offline
post #7 of 25 Old 06-09-2014 Thread Starter
jvlassak's Avatar
Raindog, thanks for the heads up about the propane locker. That's definitely something to check. I do believe it is the rudder post as the previous owner built a little clay dam around it and I found it full of water. I'll let you know what we figure out...
Iphigenia
post #8 of 25 Old 06-09-2014
Not Finished Yet
RainDog's Avatar
Got to love POs. I guess that is one way to solve the problem.
RainDog is offline
post #9 of 25 Old 06-09-2014 Thread Starter
jvlassak's Avatar
My surveyor told me it was one of the funniest things he'd ever seen.
zeehag likes this.
Iphigenia
post #10 of 25 Old 06-11-2014
Coastal Carolinas
Norstar's Avatar
If you can find someone small and limber enough to get back to the rudder post packing gland, try to just tighten up the bolts to compress the existing packing a little more. We had the same leak issue when underway and just a little snugging up on the packing adjustment bolts took care of it.
John S
PSC 34 #201
Norstar
Norstar is offline
The Following User Says Thank You to Norstar For This Useful Post:
RainDog (06-11-2014)
vertical play in rudder stock kmdudley7 Gear & Maintenance 3 04-10-2009 07:07 PM
Rudder stock moonie5961 Gear & Maintenance 5 02-21-2009 09:27 PM
HP stock falters on reports linking CEO to leak probe (Corvallis Gazette Times) NewsReader News Feeds 0 09-22-2006 11:15 PM
Catalina 27 rudder and stock wanted randall2v General Discussion (sailing related) 1 11-26-2001 07:23 AM
Need Catalina 27 rudder and stock randall2v Gear & Maintenance 1 11-16-2001 05:34 AM
HTML code is Off
