Should it (the binnacle) stay or should it go - SailNet Community
post #1 of 13 Old 06-23-2014 Thread Starter
Hush34's Avatar
Today, I continued work on Hush and started to knock out what I thought was going to be a breeze. I wanted to take the binnacle guard apart and repaint the guard table. Seemed easy. NOPE! Seems the PO (previous owner) loved the boat but didn't love to do preventative maintenance. I took the compass off with relative ease only to get to the throttle housing where four very menacing screws reside. They did not want to budge. WD 40...impact hammer, heat, nothing. Guess they didn't have anti-seize or lanacote back in the day. Anyway, I have this question? Should I continue to try and break the screws loose so I can take the pedestal table off for refab or should I simply button the whole mess back up and call it a day. If I break something, I will have to spend $1000 plus to get an edson pedestal.
p.s. I have a Merriman (out of business) steering pedestal.
p.p.s. Use anti-seize people, it will save you in the end. Whew!
p.p.p.s If you have any ideas how to break stainless fasteners from aluminum I would love to hear them.
Hush34 is offline
post #2 of 13 Old 06-23-2014
Mondofromredondo
Re: Should it (the binnacle) stay or should it go
I'd button her up and find something else that needs fixing. I've started a few projects only to find a couple hours in that the project will be 3 to 4 times bigger than I had originally accounted for. Unless it really needs to have the screws pulled I'd work around them or give up until the day I decide its worthwhile to replace everything and then get crazy !
Keith Campbell
S/V Charity Rose
'88 PSC 34'
mondofromredondo is offline
The Following User Says Thank You to mondofromredondo For This Useful Post:
Hush34 (06-24-2014)
post #3 of 13 Old 06-23-2014
If it aint broke--dont fix it.
Dianne and Chuck Burke S/V NiftyNickers
niftynickers is offline
The Following 2 Users Say Thank You to niftynickers For This Useful Post:
granche1 (06-27-2014), Hush34 (06-24-2014)
post #4 of 13 Old 06-24-2014
Sailboat Reboot
svzephyr44's Avatar
Send a message via Skype™ to svzephyr44
Patience... If you can leave it open. Spend 10 minutes each day to spray it with "Blaster" (better than WD-40) and apply a little heat. If that does not work in a week or two then you can drill out the screws, re-tap the holes, and start over (with anti-seize.) Normally I might agree with leave it alone - but I gather you have no access to the throttle and shift controls nor to the gears for your wheel. You don't want to be in a position to try and break the screws open when you have an engine or steering failure at sea!
Fair winds and following seas
CAPT Roger J. Jones USN (ret.)
Sailboat Reboot
411 Walnut Street, #9700, Green Cove Springs, FL 32043-3443
Reboot's Agent's Email:
Web Site:
Blogging:
Twitter @Sailboat_Reboot
svzephyr44 is offline
post #5 of 13 Old 06-24-2014 Thread Starter
Hush34's Avatar
Those were my thoughts. Failure at sea cannot fix it then. I think I can access the cables enough to swap out if necessary. Not sure. More to investigate in the mean time blaster a day to keep the corrosion away. Will let you know how it progresses. Thanks for the thoughtful input.
Hush34 is offline
post #6 of 13 Old 06-25-2014
Hush,
I took the Merriman binnacle apart on my 1988 31. Of the four bolts the first was difficult, second was very difficult, third broke the top off the bolt but was able to cut a slot and remove and the fourth I had to drill out.
After that it was easy to replace steering cables, throttle cable and transmission cable. I had it sand blasted and powder coated. It looks great.
John
wmjr is offline
The Following User Says Thank You to wmjr For This Useful Post:
Hush34 (06-27-2014)
post #7 of 13 Old 06-25-2014
Save the WD-40 for dewatering things.
First, order a hand impact driver in the mail. About $20 for a brand name, nothing that might fly apart on you. And safety goggles if you don't own them. And a dead hammer or maul.
Use PBlaster per the directions, repeat 2x-3x.
Now use the impact driver on the screws. First whack can be set to "tighten", but make Real Damned Sure it is set to "Loosen" after the first whack. They will come out.
And anything except an impact driver, will chew up old slotted screw heads when you have to work them that hard. It is a tool you will rarely use, but you'll be very happy to have it when you need it. Keep the goggles with it, flying metal splinters can ruin your day if they do happen.
hellosailor is offline
post #8 of 13 Old 06-25-2014
Old enough to know better
This +1
WD40 is not a lubricant or penetrating compound, it is a water displacement chemical. Save it for cleaning duty. Use Kano, Liquid Wrench, or PB Blaster in that order. You cam use auto transmission fluid as well.
Manual impact drivers are great and no boat or British car should be without one! $15 and it will last a lifetime.
Sent from my ADR6425LVW using Tapatalk
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #9 of 13 Old 06-26-2014
Have a spare Merriman that I need to sell one of these days as I converted the boat to tiller. I would sell it for less then $1000.
Yacht Specialities/Merriman went out of business in 1989 and I was fortunate to have to one of the last Merriman steering pedestals installed on the boat as it was delivered in Dec 89.
Marc
Crazy Fish - Maintaining, Upgrading and Sailing a Crealock 37
MarcHall is offline
post #10 of 13 Old 06-27-2014 Thread Starter
Hush34's Avatar
I have followed the advice of the PB Blaster crowd. I sprayed the fasteners liberally with this stuff and followed the instructions about tapping. Will be gone for a week. When I get back the impact driver will be going to work.
Of note...the heads of the screws seem to torque under load but that torque is dissipated by the length of the screw and not much seems to get to the threaded portion down the shaft.
If this doesn't work, I will be taking a cobalt drill bit to the heads to remove. I am sure I can get the screws out if I can just get some torque to the lower part of the shaft.
The binnacle is staying, the screws are going...
p.s. I decided I could not simply button this problem up because of the likely potential of cable failure and not being able to correct. We are leaving in January to start our voyaging. Thanks for all the input.
Hush34 is offline
Why a binnacle compass?? SVTatia Gear & Maintenance 9 12-01-2013 01:21 PM
Binnacle and Knotmeter Lighting Traveling Light Pearson 3 10-02-2010 07:26 PM
Wheel and Binnacle to Tiller? SEMIJim Gear & Maintenance 9 06-21-2007 07:52 PM
Passport 40 binnacle winethief Gear & Maintenance 1 06-12-2007 07:51 PM
wheel/binnacle wilhelm Gear & Maintenance 3 08-26-2003 07:36 PM
HTML code is Off
