LPG solenoid switch by Newmar - replacement? - SailNet Community
post #1 of 15 Old 01-07-2016 Thread Starter
My Pacific Seacraft 37 has a fused LPG solenoid switch that I'd like to replace. It works most of the time, but the fuse holder has a tiny piece that's broken so the fuse won't stay put. Alas, the maker of this panel (Newmar) doesn't make it anymore, and a company that did make a replacement (Seaward) apparently went out of business. There are some similar switches out there, but I cannot find one that's close to the same size (mine is 3 1/4" x 4 1/2").
Has anyone with a Pacific Seacraft (or anyone else reading this) replaced this unit or found an alternative approach? In my ideal world, I could replace just the fuse holder, but I'd be happy if I could find a whole new panel of similar size.
Now for a bit of ranting: I won't go into detail about the trials and tribulations of LPG cooking, but a warning to folks sailing to far corners of the planet: some governments don't allow you to refill your boat's LPG bottles, and some of the same places don't allow use of alternative bottles that will fit into a PS37 gas locker (and good luck finding gas fittings to hook up the fat alternatives). Have a backup plan, or steel yourself to eat cold food straight from a can (which is probably fine, but I'm old enough to remember the days when that was considered extremely risky to one's life).
Lantau is offline
post #2 of 15 Old 01-08-2016
Location: The house is in Kingsport, TN. Boats are on Watauga Lake and in New Bern, NC
Re: LPG solenoid switch by Newmar - replacement?
Originally Posted by Lantau View Post
In my ideal world, I could replace just the fuse holder...
Try Googling "panel mount fuse holder" or "panel mount square head fuse holder" and look at the images. If you can't find the square holder locally, it looks like it fits in a 1/2" diameter round hole, and any common fuse holder for glass fuses would fit in the hole.
wsmurdoch is offline
post #3 of 15 Old 01-08-2016
Old enough to know better
http://www.amazon.com/Seachoice-Squa...re+fuse+holder
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #4 of 15 Old 01-08-2016
Take a look at posts 83 and following of this thread. Propane Solenoid experiences , good/bad/best - Page 6 - Cruisers & Sailing Forums I've had trouble filling tanks even here in the US. Having the ability to decant one tank into another is a handy skill.
post #5 of 15 Old 01-08-2016
I know of this switch panel with a circuit breaker, there may be other sources.
005-805 Propane (LPG) Solenoid Control Switch
"Just call me TB"
capttb is offline
post #6 of 15 Old 01-09-2016 Thread Starter
Thanks to everyone for the suggestions to find a replacement fuse holder. Alas, I haven't found one that looks like it'll fit. The holder on the Newmar panel has a little plastic nib (or had it; it broke off) that secures the holder inside the switch box. The switch works fine if the fuse holder his held in place. (If I can find a three-handed cook, he/she could to hold it in place and use the stove at the same time.)
In one of the threads that was recommended in another reply, someone does mention the problem with this switch: Whale bought out Seaward (who started making it after Newmar stopped doing so, for lack of parts) and then discontinued the product. Such is the world today.
Alas, the new panel that I'll probably have to go with (pointed out in another reply) is much smaller than the Newmar panel. It'll work fine, but I'll have to fabricate something to cover the hole in the boat's woodwork. This is going to be one of those super simple jobs that takes at least a whole day, but only after I gather up all the parts and materials (that is, weeks/months away). As I often remind myself, it's a boat!
Lantau is offline
post #7 of 15 Old 01-09-2016
Hi
Are you a little bit of a handyman ?
take that panel off , and look at what is behind , where that fuse is , can you replace that set -up with a new fuse holder or an in line fuse ?
that would be the easiest , and cheapest for you , and very safe as well
good wind
rioux.lm@bell.net is offline
post #8 of 15 Old 01-09-2016 Thread Starter
Originally Posted by rioux.lm@bell.net View Post
Hi
good wind
Good idea; you were reading my mind! If the internal wiring allows for this, I can simply glue the (empty) fuse holder back in place for aesthetics. I tried once already to get the panel off, but it didn't come out easily. It may be glued in as well as screwed. I will make another try but must be prepared for something to get damaged in the process. My first choice was to replace the fuse holder, thus avoiding all of this.
Lantau is offline
post #9 of 15 Old 01-10-2016
s/v Pelagic
Sure Marine in Seattle makes their own small, fused switch panel for LPG solenoids as well as selling Seward and Trident panels. Since they make their own they may have some parts you could use to repair yours. Sure Marine Service, Inc. * Since 1972 * Webasto Marine Heating, Air Conditioning, and Galley Equipment
John
s/v Pelagic
1980 C37 Yawl
jnewcomer is offline
post #10 of 15 Old 01-10-2016 Thread Starter
John
s/v Pelagic
1980 C37 Yawl
Many thanks John. Alas, I tried Sure Marine previously. They had the Seaward panel I want on their website, but when I tried to order it they came back with apologies that it's no longer produced. As you say, they do make the smaller panel.
I haven't used Sure Marine, but they look like a good source of cooking-related parts I will want to buy eventually.
Lantau is offline
Solenoid switch does not shut off propane Jiminri Gear & Maintenance 22 01-09-2016 06:42 PM
Newmar chargers deniseO30 Electrical Systems 13 06-05-2014 11:23 PM
Newmar RM15 battery charger db27513 Gear & Maintenance 3 01-12-2008 12:25 PM
Pull engine switch replacement Neicy Gear & Maintenance 12 09-06-2005 06:05 AM
Lewmar Commander 4 Solenoid Replacement sci_fi Gear & Maintenance 1 01-23-2001 02:53 AM
HTML code is Off
