Engine mount - SailNet Community
post #1 of 8 Old 02-07-2016 Thread Starter
Engine mount
Engine mount is bolted to the raised bed. Noticed that one bolt was not seated. Marina raised engine when replacing transmission.....guess they didn't think it was important to tighten it. I tightened but it didn't resist when seated against the lock washer. I didn't keep tightening. Anyone know how the engine mounts are bolted to the raised bed? Is there a nut underneath, below the fiberglass bed?
PCSSailor is offline
post #2 of 8 Old 02-07-2016
Re: Engine mount
Maybe just a rotted beam of fiberglassed wood .Not to worry as long as you don't heel under sail and the engine falls over
Capt Len is online now
post #3 of 8 Old 02-07-2016
Beyond The Pale
Erindipity's Avatar
Re: Engine mount
Um, going around and randomly tightening Engine Mount bolts is Not A Good Idea. A proper Marine Mechanic should chime in here, but when the Engine/Transmission is aligned to the Propeller Shaft, Mounts can look a bit odd. But there it is- Boatbuilding isn't yet an exact Science.
The important thing is that the Propeller Shaft is aligned; if it is not, all sorts of irritations will occur, like when on Rundown, the shift in the Engine Mounts may make the Shear Pin, if the setup has one, to... Shear. That is what it is supposed to do. (If CV Joints were commonly used, which they are not, this wouldn't be a problem.)
I went through half a dozen Shear Pins on my last Boat, a decade or three back, before I figured this out- The Mechanic who had reinstalled the Volvo MD2B for the previous owner, after an unfortunate intake of Seawater, just jammed everything down tight. (That wasn't the only thing done wrong...)
Raising the Starboard Rear Mount about 3/64 of an inch, the thickness of a SS Washer, was the solution, and the Packing Gland stopped leaking as well. And I eventually installed a CV Joint, from an old Audi Fox, just in case. (This set the Propeller back around three inches, which wasn't a problem.)
I don't know about the installation on your particular Boat...
I also don't know about the installation on my current Boat; it just works, and whoever did the installation knew _exactly_ what they were doing. There is some sort of Rubber Booted Thingie going from Aft Propeller Shaft to Fiberglass. I do know that the Thingie is French, and that there is a French Manual for it, which was included in the purchase, as well as some spare O-Rings.
If I ever have problems there, I shall have to brush up on my French.
It seems to me that you need a proper Marine Mechanic, which I am not.
I just muddle through problems, and trundle through waters.
Best of Wishes;
ČErindipity
Erindipity is offline
post #4 of 8 Old 02-08-2016
Omatako's Avatar
Re: Engine mount
Normally the bolts that hold the engine mounts to the bed-way will not influence propshaft alignment. If you resist fiddling with the bolts above that set the height the mounting (see thumbnail), the shaft will stay where it is. The other bolts/mountings will keep everything where it is.
Also normally, the bolts that are used are really just large wood screws with a hex head. It is quite rare for any form of nut or tapping plate to be embedded into the wooden beam. If it is stripped, there are two options - first is to increase the size of the bolt/screw. The second is to knock a peg of hardwood into the hole, cut it off flush and screw the original screw into it. The second would be my choice.
Arthur C. Clarke
Omatako is offline
post #5 of 8 Old 02-08-2016
BMLipiec's Avatar
Re: Engine mount
Omatako is right. One of our bolts(screws) was stripped and just spinning in the hole. I filled the hole with thickened epoxy and re-drilled the hole. That was two years ago and it has held fine. Because they are just giant wood screws they can easily strip if you really torque down on them.
Brian & Marya
S/V Indigo
Pacific Seacraft 34
Hull #281
BMLipiec is offline
post #6 of 8 Old 02-09-2016 Thread Starter
Re: Engine mount
Thanks for everyone's advice. I'll try the epoxy.
post #7 of 8 Old 02-09-2016
DaveMancini's Avatar
Re: Engine mount
I ditto BMLipiec (Hi, Brian!). If the lag bolt is for one of the aft mounts (especially if it is the aftermost bolt on an aft mount), there is one big caveat: when you extract the lag bolt, measure the depth of the hole the lag bolt actually makes below the surface of the engine bed after going through the engine mount and washer. Then, be very careful not to drill any deeper than that into the new epoxy when you replace it. The hull is very close to the engine bed at that point. It is possible to drill right through the hull if you are not careful.
Dave Mancini
PSC34 #305 Swan
DaveMancini is offline
post #8 of 8 Old 02-09-2016
BMLipiec's Avatar
Re: Engine mount
Hey Dave! Good point, I should have mentioned that. The lag bolt you mentioned was the same one I had to fix.
On a related note and added caution: I almost drilled through the hull of my last boat (above the waterline) when the bit depth stop I was using backed off slowly after multiple holes. I kept drilling a little deeper each time and almost drilled through before I realized it. It was one of those metal collar stops that fit over the bit and tightened down with an allen screw. I no longer trust those things.
Brian & Marya
S/V Indigo
Pacific Seacraft 34
Hull #281
BMLipiec is offline
Engine Mount needed. redx Gear & Maintenance 7 01-05-2015 09:32 AM
Engine Mount - Holder 14 Spin Gear & Maintenance 4 10-31-2013 10:34 PM
Engine Mount Issues... tkawika Diesel 5 07-08-2011 06:51 PM
Need help YANMAR engine mount Giulietta Gear & Maintenance 20 04-15-2010 01:15 PM
replacing engine mount Radicalcy Gear & Maintenance 0 09-29-2004 08:05 PM
HTML code is Off
