I'd like to find replacement covers for our bronze hawse pipes on Jo Beth. She's an '84, so these are the 'old style' types. I hesitate to call them 'oval', but I believe that's how they're identified. Specifically, I'm looking for ones with hooks to hold the end of the rode up and ready.
Anyway, I've looked all over - Spartan Marine Hardware, Bristol Bronze, Buck-Algonquin, and so on...but no luck. Any suggestions?
I've found plenty in SS and chromed bronze, from Hamilton marine, West Marine, Defender, etc. Finding them in good ol' bronze seems to be the issue - and Spartan Marine does have them in bronze, but not the correct size...
I haven't looked on E-Bay yet. I did send Thumper a note, but he's not answered.
I'm wondering about taking the covers and cleaning up the undersides of each with a wire brush/grinder wheel, and tack-welding (or 'tack-brazing') a new hook on them...then attaching new chains...or figuring out another way to secure the rode end to the cover.
Old bronze hot water tanks are an excellent source of raw material. Easy to fill and fillet , gas,neutral flame ,dip strips of same material in flux ,can be hammered and annealed . If all you need is the hookme,drill a hole and modifiy an eye bolt.
I know that you are looking for replacement covers for the hawse pipes on your PSC 34. But, if you still have the original covers, and all you want to do is add a hook... on my PSC the original covers have a little raised and drilled tit on the inside bottom of the hinged cover. I tapped the hole and screwed in a bent stainless eye bolt. I did it on both the hawse pipe cover on the bow and the similar cover in the stern. On the bow I now use the eye bolt to hold the end of a bungee cord that keeps the cover closed with the starboard side anchor chain passing through the notch in the cover on its way to the anchor. On the stern the end of the chain is tied with a little piece of 1/8" cord to the bow shackle at the end of the chain so that the weight of the chain keeps the cover closed and so that I can find the end of the chain when I need it.
Are your hawse pipe covers smooth on the inside, or do they have a raised bit? I don't have a photo of mine and will not be back on the boat until mid January, but I will take a picture when we return to the boat.
I've thought of this as well. I'll take a look when I'm home this afternoon. My cover's aren't hinged though, they are/were secured with chain lanyards, which I believe were of brass...but yes, the hook is primarily what I'm after.
I've made many bronze parts from cleats,rode pipes to anchor rollers from bronze. Make a pattern (plaster, plywood, it doesn't matter) or if you have another of the same part take it to any local foundry (every city has at least a couple) and have it sand cast. I had some done last year and was charged $6/lb.
Lots of stuff on Youtube about how you can even do this at home.
It's possible a Westsail 32 hawse pipe & cover is the same as a Crealock since Bill Crealock did both of them. If that's the case the main resource for W32 parts is Bud Taplin, ex-general manager of Westsail. His site is: www.westsailparts.com - About Us. I checked his parts listing and he shows this item: DKPIPOVL Oval Deck Pipe for anchor chain - SS AA56005 40.00 each.
Have a complete one that's surplus to me. Used but in decent shape. We're away from home till after New Years so would have to wait to ship. Make me an offer.
I had the same issue with my cover on my Cape Dory 30B. The starboard cover was missing and using tin cans and plastic was just not cutting it. I looked into having one made and it was going to involve providing the other cover for a period of time as well as $200 or so in cash.
Based upon recommendations I stopped by at Bacons Sails (I have no association with them other than being a satisfied customer) and asked about available covers. I was directed to a box of various covers and in about 5 seconds discovered the exact match for my missing cover. It was a complete set to include the thru deck fitting so it likely cost me a bit more but for the grand cost of $10 the set was mine.
I took off the deteriorated chrome with some sandpaper and the results turned out so nice that I went ahead and put some clear coat on it. Now I have to do the port side!
I would recommend giving Bacons a call, they seem to be very helpful. Their number is 410-263-4880. Even with shipping costs you might save a few bucks.
I've added a couple of photos of what I got, you can see what the cover looked like prior to cleaning off the chrome:2 boat: by looking at the deck fitting.
I should have noted (since some folks might, especially not in the Chesapeake bay area and may not be familiar with Bacons) that the establishment has sailing "junk" like what someone would have in their basement after sailing for 50 years but multiplied by a million. I spent half a day there just looking and couldn't depart without spending a lot more than the $10 for the cover...many other treasures. I understand they got their start by recycling used sails and then expanded.
A couple of years ago we lost a cover overboard because the chain broke. I couldn't find a replacement so a fabricated one out of sheet brass and some solder. It wasn't too hard and it looks OK as it weathers to a nice patina.
I read somewhere that Minney's bought out surplus hardware (much of it from Chatfield, New Zealand) from PSC when the factory folded out in California. You might give them a try Minney's Yacht Surplus - Home
Related Threads
1.7M posts
173.8K members
Since 1990
