Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
  #1
Old 01-16-2007
Philip Littman is on a distinguished road
electric fuel pump
I have a PSC 34, 1998 with a 3jh2 engine. The electric fuel pump used for priming the racor after changing filters is no longer working. I believe it is a Walboro which does not seem to be availble now. What should be the replacement pump? Phil Littman
  #2
Old 01-16-2007
camaraderie's Avatar
moderate?
If it is a standalone 12v pump...just bring it up to your NAPA store and get the closest thing to it...it will work! Make sure your pump is between your Racor and the engine...NOT between the tank and the racor which causes pre-mature failures of the pump due to debris build up.
  #3
Old 01-20-2007
Senior Moment
RickBowman is an unknown quantity at this point
Phillip,
We have the same engine, mine being 1 year older then yours. (1997 Yanmar) and both were installed by PSC. My Racor 200R Spin-on Series Fuel Filter/Water Seperators for Diesel Engines Manual details the fuel transfer pump before the filter, not after it. Sorry Moderator, that's what is in print.
The fuel tank outlet(s) on my 1997 PSPH are positioned above the Racor Filter, hence may be the reason why I do not have the fuel transfer pump that is installed in your PS? Is your transfer pump located in the bilge area?
Rick
  #4
Old 01-20-2007
Location: Ft. Lauderdale, FL currently CLODs [cruisers living on dirt]
svsirius is on a distinguished road
to act as a prime pump pump needs to be before.. fuel pumps can not generally suck air....
Jon D
SV Sirius
Moody 47
  #5
Old 01-20-2007
moderate?
Jon...putting the pump before the racor voids the pump warranty AND causes lots of pump problems...(personal experience)...and it does work priming the system after the Racor if you have some fuel in the line which requires the pump to be mounted lower than the Racor. Worked like a charm when I made the move on my last boat.
You may post attachments
You may edit your posts
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Devising a Better Bilge Pump Don Casey Seamanship Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Gear and Maintenance Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Cruising Articles 0 06-02-2002 08:00 PM
SEO by vBSEO 3.6.1
