Even with a good survey, there are many unseen horrors - Page 2 - SailNet Community
 11Likes
post #11 of 35 Old 04-19-2017
Re: Even with a good survey, there are many unseen horrors
Congratulations on the new boat. I go into every new boat and every new season with the expectation I'm going to find something major. I wonder what it will be this time. Then it arrives. Then I know and I can move on. I haven't solved this season's yet.
If your version of major is a stripped ground bolt, I'm very jealous.
Jeanneau 54DS
Minnewaska is offline
post #12 of 35 Old 04-19-2017 Thread Starter
Thanks. I'm actually going into my second full season, but still very much a neophyte with regard to all the systems on the boat.
I agree, even though it could have caused a major problem, the repair is relatively cheap and easy. -- I do wonder how in the world this was actually done. I don't think it was done by the PO (what owner would have made a connection this bad?). The yard that she was at before I bought her is well respected. But nonetheless, whoever did the previous repair must have known it was stripped. --
elliowb is offline
post #13 of 35 Old 04-19-2017
If you're going to move the ground connection to a new spot, the best place is one of the starter bolts if you can do it. Puts the voltage right where you need it with less resistance. You're not relying on the starter's connection to the engine to transfer the power. That can gunk up and add resistance. Usually the worst that can happen with a bad ground is the engine won't start, but in an emergency I guess we could call that major.
capt jgwinks is offline
post #14 of 35 Old 04-19-2017
Originally Posted by elliowb View Post
.....I agree, even though it could have caused a major problem....
Other than your starter may not have turned over to start your engine, when you needed it, what major problem do you envision this could have caused?
Jeanneau 54DS
post #15 of 35 Old 04-20-2017 Thread Starter
In my book, predominantly as a single-hander, that would be enough (although I do have a portable battery and the anchor is at the ready if need be). However, one of the other things I'm thinking would be a problem is that I'd be without running lights.
I'm not that familiar with diesels yet, once started, will a diesel run without a battery?
elliowb is offline
post #16 of 35 Old 04-20-2017
Towguy's Avatar
Actually your house battery's ground should be seperate,I think,and I assume your running light are run off them.. And yes older ,none computer run,mechanical diesels will run once started..actually if it's a battery problem any engine with a alternator/generator will run once started,also your idea of a boost battery may have worked if you had put ground straight to the engine and not tried to boost the battery as that would have been fruitless with a bad ground!......a good way to check for a bad ground ,is run a booster cable from starter battery to block creating a new ground.......Ralph
Northern Alberta. "85" C/L 16. ,"85"S2 7.9 under repair.
Towguy is online now
post #17 of 35 Old 04-20-2017
Gail Peterson's Avatar
Yes, the battery just provides the spark for ignition. Once started, the diesel runs without juice from the battery.
1973 Cutter-Rigged Pearson 39 "Brandy"
______________________________________________
"Mama always told me not to look into the eyes of the sun. But Mama, that's where the fun is...." ~Manfred Mann's Earth Band
Gail Peterson is online now
post #18 of 35 Old 04-20-2017
No spark on a diesel, the fuel is ignited by compression only. The battery just turns the electric starter motor.
fallard and Gail Peterson like this.
Jeanneau 54DS
post #19 of 35 Old 04-20-2017
Location: The house is in Kingsport, TN. Boats are on Watauga Lake and in New Bern, NC
elliowb,
My battery selector switch on Irish Eyes is mounted directly on the plywood below the companionway, not on a separate piece of plywood screwed over a large opening. Perhaps someone has modified your original installation. All the wiring on the back of my switch are one ring fitting to the wire. Nothing is doubled up.
My engine ground connection is on the aft port corner of my engine (Yanmar 3HM35F) near the tachometer sender. Both the battery negative and bonding grounds are connected to a bolt in the engine block adjacent to the starter motor mount. (I previously had a second battery negative cable going to the alternator frame, but the new alternator I installed this year does not have a suitable bolt. So, until I figure out how to work around that, I have left the cable off.)
I have had a bad engine ground. When Mac Boring rebuilt my engine they repainted it. When the engine was reinstalled in the boat, the paint partially insulated the metal under the bolt and the underside of the bolt head. Until I found the paint, I had problems with the starter motor, the oil pressure gauge, the engine temperature gauge, and the alternator regulator. I never had the opportunity to test the oil pressure and engine temperature switches, but I'd bet they had problems as well. Scraping away the paint fixed all the problems.
Bill Murdoch
1988 PSC 34
Irish Eyes
oysterman23 likes this.
wsmurdoch is online now
post #20 of 35 Old 04-22-2017 Thread Starter
Originally Posted by wsmurdoch View Post
elliowb,
Bill Murdoch
1988 PSC 34
Irish Eyes
Thanks for the great info and the photos Bill. The original battery switch is the same Perko switch that you have on Irish Eyes. I made the cutout so that I could more easily access the cables and I'm going to install a BlueSeas on/off/emergency switch. It is very possible that someone has altered the wiring prior to my purchase (especially since the ground on the engine has clearly been altered).
The second photo of the aft port side of your engine is helpful. The 3/8th hole that is in the support that runs athwartships, a bit inboard from the engine mount, just aft of the location that your ground is attached is where my ground was attached. Since the threads were very thoroughly stripped, I drilled a new hole in the same support, just inboard of the original hole and threaded it. Tomorrow I'm going to install a bus bar on the port wall of the engine compartment. I think that should solve that part of the problem that I encountered.
After removing the cable from my start battery, I discovered even more reason for why I'm happy that I am replacing some important elements in the DC system. The better part of the lug has been eaten away, due to the stripped ground bolt.
-- Bill Elliott
Belle Voile
elliowb is offline
How long is a survey good for? plaster93 Boat Review and Purchase Forum 4 10-20-2012 02:42 AM
A good survey today! Perithead Boat Review and Purchase Forum 23 01-23-2008 03:21 PM
Good survey can boost boat value - Daily News - Galveston County NewsReader News Feeds 0 07-02-2006 01:16 AM
Re: Paul, if it's still available I'll take it, sight unseen! NewsReader Mass Bay Sailors 0 04-24-2006 02:15 PM
HTML code is Off
