Blogs
Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
User Name
  #11 (permalink)
Old 04-03-2007
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enough
They charge that much for it?! What, is $500 for the software side?
  #12 (permalink)
Old 04-03-2007
RickBowman RickBowman is offline
Senior Moment
RickBowman is an unknown quantity at this point
hellosailor,
Included in the kit,
1. Marine XM Weather Antenna/w/50 feet of cable.
2. Base unit
3. Mounting bracket for the base unit
4. Auto XM antenna with magnetic base.
5. USB cable for laptop connection
6. 12 volt power adaptor
7. Software
8. Delphi XM radio receiver
8. free activation for XM Weather and Radio
9. free first month for XM Weather and Radio
10. free annual deactivation, free activation next year
  #13 (permalink)
Old 04-11-2007
Senior Moment
Originally Posted by arisatx
Rick:
Thanks for the tips on MI DNR.
re: your question on the Zinc - it's on the prop. Click here.
I'm not looking forward to the impeller swap out based on all the comments here on this board.
Did I mention, I'm launching in less than a week.
Ted,
I found the anode. It's on page 360 of the west marine 2007 catalog. We don't have the same prop, yours has gears, is adjustable and feathers? Mine just drags along for the ride.
Rick
Sponsored Ad
  #14 (permalink)
Old 04-12-2007
arisatx's Avatar
arisatx arisatx is offline
arisatx is on a distinguished road
Thanks Rick - will take a look at West's catalog when I get home.
Regards,
Ted
S/V Talisman
PSC 37 #359
  #15 (permalink)
Old 04-12-2007
Senior Moment
Ted,
I ordered zinc #cmpnzd based on the 1.25" dia prop shaft that this PS32PH uses. I'm also missing the bolt that holds the anode to the prop nut and it appears to be a 5/16 x 18? We are in fresh water and not nearly the concern like the saltys have, but it will protect the brass prop from electrolitic corrosion. I took off the godgeon today and have the rudder supported by a floor jack. I'm going to wire wheel all of the undercoating off of it from the po, grease it up and reinstall it. After taking a mirror and looking up the rudder tube I see a cement type bedding inside of the pipe but it doesn't fill it up from side to side. I have no idea why that would be in there and as far as I can tell looks like it has something to do with the rudder sticking to it and not with sealing off the tube from water, which it wouldn't be able to do the way that it is. That tube has got to be drilled in numerous spots with some sort of a steel reinforcement going into the rudder and perpendicular to the tube, right? The rudder pipe or tube sticks about 1.125" out of the bottom of the rudder and the receiving gudgeon brass bushing is approx 1.375 deep. Both the pipe inside of the rudder and the bushing have seats that are the main contact point. No wear noticed after polishing and of the surfaces. The bushing in the gudgeon has about a .25" hole in the bottom of it, a little small for zebra musscels, I hope. Next year I'm going to shove grease into that bushing hole and call it good. It appears that the gudgeon, bolts and nuts were well sealed from water and I plan to reseal them at least as good.
Rick
  #16 (permalink)
Old 04-17-2007
Senior Moment
Angry 3Jh2e Yanmar
Rick:
The impeller is about 6 inches below the space between the alternator and the heat exchanger and the cover for it faces aft. That is why the alternator has to be removed for access to the impeller replacement on this vessel.
  #17 (permalink)
Old 04-17-2007
Rick, that elbow hose above the alternator looks like it was factory painted--and is now already cracked and ready to replace.
Don't tell me...they hired the alleged engineering team from WesterBleeech ?!
  #18 (permalink)
Old 04-17-2007
Senior Moment
Hellosailer,
If you look at the alt belt you see the same thing as the hose; cracked paint. It sure makes a mess in the engine compartment.
Display Modes
vB code is On
HTML code is Off
Off-Season Boat Projects Tom Wood Gear and Maintenance Articles 0 01-15-2006 08:00 PM
Hurricane Season Tom Wood Seamanship Articles 0 07-24-2003 09:00 PM
First Sail of the Season Bruce Caldwell Gear and Maintenance Articles 0 06-05-2003 09:00 PM
Contemplating Hurricane Season SailNet Seamanship Articles 0 05-19-2001 09:00 PM
Considering the Cyclone Season Options Doreen Gounard Seamanship Articles 0 01-18-2001 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
