Blogs
Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
User Name
Old 07-02-2007
Mortimer49735's Avatar
Mortimer49735 Mortimer49735 is offline
Mortimer49735 is on a distinguished road
Pacific Seacraft 31-Water Tank Leak
I have a 1989 Pacific Seacraft 31. It has two water tanks. The bow tank has a plexiglas cover over the entire tank that is siliconed in place as an observation port and then a loose plywood cover is fitted over the plexiglass.
However, on the aft water tank the plywood cover is also siliconed in place on top of the plexi-glass. This eliminates the ability to view inside the tank. This tank leaks from the top when on a starboard tack despite having both the plexi-glass and plywood panel siliconed in place.
Of course the easiest solution is to never sail on a starboard tack . . ., but we are looking for a better solution. Any suggestions on how to separate a phywood panel from silicone and/or a better sealant. The leak is on the port side midway on the full curve.
Old 07-02-2007
Sapperwhite's Avatar
Sapperwhite Sapperwhite is offline
Not So Senior Member
Sapperwhite has a spectacular aura aboutSapperwhite has a spectacular aura aboutSapperwhite has a spectacular aura about
Mortimer,
I also have a PSC, and have recently done alot of work to my aft water tank.
I have an Orion, and the aft tank is under the sea berth in the port quarter, I think yours would be aft of the galley under the cockpit on the port side, correct? Anyway, my aft tank vent had began leaking, and to repair the leak I had to remove the lid. My tank lids are plywood with a hard water proof coating on the underside (can't remember the trade name for this board right now), the face that is in the watertank. Mine also have clear screw on hatches that are about 6 inchs across for tank cleaning and accessability. I had use a razor knife to work all the way around the seam for the hatch, and then slowly go around the edges prying the lid off with acouple of thin pry bars and flat head screw drivers. I went really slowly so as not to delaminate the plywood cover. If its just the cover that is leaking , then you should remove ALL of the old silicone, so you have good clean faces when you go to rebed the lid. Apply planty of new silicone and clean up the excess that oozes out as you go. I left some heavy items around the lids rim after reinstalling so that the lid was well set in place whille the silicone set.
If you don't have the same type of access hatches that I have,or something similar, it is something to consider installing once you get the tank lid off. They are about 6, maybe 8 inches across, and they make cleaning and inspecting the tanks a breeze.
I do not have full plexiglass covers with plywood inserts like you do, but I imagine that the lid removal procedure would be about the same for both of us though. Rebedding the whole thing would cure the leak I bet.
Old 07-08-2007
arisatx's Avatar
arisatx arisatx is offline
arisatx is on a distinguished road
Inspection Ports
Mortimer:
If you decide to install inspection ports (or re-install existing ones like in my case after cleaning) I found that using silicone sheet stock available from McMaster worked very well as a gasket.
McMaster
Regards,
Ted
S/V Talisman
PSC 37 #359
Sponsored Ad
Old 07-10-2007
stevemac00 stevemac00 is offline
stevemac00 is on a distinguished road
We had to replace the bow water tank top on a 31. Ended up using Starboard - more expensive but easy to work and stronger than PVC. Here is some handy instructions provided by Robin at PSC a couple months ago.
http://i208.photobucket.com/albums/b...structions.gif
Old 08-28-2007
Thanks to the group and particularly to Sapperwhite for his detailed response. It's nice to know your not alone or the only one with a particular boat problem.
Display Modes
vB code is On
HTML code is Off
water tank buildup smaconf@msn.com Hunter 2 11-30-2007 09:51 AM
Possible Water In Diesel tank sabre28guy Sabre 1 05-18-2007 10:40 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 08:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 08:00 PM
Beyond the Bucket Brigade Brian Hancock Seamanship Articles 0 01-01-2003 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
