Blogs
Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
User Name
Old 11-19-2007
waypt1 waypt1 is offline
waypt1 is on a distinguished road
PS 37 Cutlass Bearing
I need to replace the cutlass bearing on our PS 37 #347. I would like to have the replacement bearing in hand when the boat is put on the hard. I know the shaft is 1 inch but need to know the outside diamenter of the cutlass bearing. If you have replaced the cutlass bearing on a PS 37 and know the O.D., I'd sure like to hear from you.
Also, if you have changed the cutlass bearing without dropping the rudder, I'd really like to hear how you did that.
Roland Snyder
Wayward Wind
PS 37 #347
Old 11-19-2007
arisatx's Avatar
arisatx arisatx is offline
arisatx is on a distinguished road
Roland:
I can't help much in answering your question, but I am interested in hearing everyone's feedback, as I believe I'm not too far behind you with #359.
How many hours do you have on your PSC, may I ask?
Regards,
Ted
S/V Talisman
PSC 37 #359
Old 11-20-2007
Hours on diesel
We have 830 hours on the engine
Old 12-14-2007
Zest Zest is offline
Zest is on a distinguished road
PSC37 cutlass
Roland,
I own hull #372 (recently purchased) with ~1000 hours on my Yanmar 4JHE. I just replaced the cutlass bearing (which was in bad shape). The yard told me they completed the job in 30 minutes (incidently, the yard who hauled me for the survey told me that they would likely need to remove the rudder - happy to say , I did not use that yard!). Sorry I cannot help you with the dimensions.
Ken Eckert
"Zest"
Moss Landing, CA
Old 01-15-2008
Psc242 Psc242 is offline
Psc242 is on a distinguished road
How to remove Cutlass bearing?
I own a Crealock 37 Hull # 242.
I replaced the cutlass bearing without removing the rudder.
Remove the prop and look first, how much of the cutlass bearing is exposed? If it exposed more then ¼” than I believe, that you can do it.
I bought a 1and a ¾” cast iron coupling (Home depot) . I drilled and tapped 8 holes around for a 8/32 machine screws, ¼” from one end of the coupling. Than I grind the tips of the screws to a point, to make them work like a set screws.
After removing the small screws that hold the cutlass bearing to its place, I installed the coupling and the set screws into the exposed cutlass bearing. (Try to grip the cutlass as far from the end as possible.) I tighten the screws real good, and than, using a prop puller, I pulled on the coupling and got the bearing out. It takes few minuets, once you have the coupling ready.
The Cutlass bearing is: 1"x1 3/8"x 4"
Old 01-15-2008
AjariBonten's Avatar
AjariBonten AjariBonten is offline
Aquaholic
AjariBonten is on a distinguished road
Hi PSC, welcome aboard.
That is a really ingenious way to handle that situation. It seems like replacing cutlass bearings is either "no problem" or a "total PIA" depending on the circumstances. I've done it twice (lobster boats) and had one of each experience.
30 minutes once, 3 days the other.
I got an Old Fat Boat
She's Slow But Handsome
Hard In The Chine, but Soft In The Transom
I Love Her Well, And She Must Love Me
But I think It's Only For My Money
..... Gordon Bok
Display Modes
vB code is On
HTML code is Off
How to Replace Cutlass Bearing? kcoffey General Discussion (sailing related) 1 12-05-2004 06:13 AM
Repairing Cutlass Bearings Mark Matthews Gear and Maintenance Articles 0 05-07-2002 08:00 PM
Installing a Cutlass Bearing Mark Matthews Gear and Maintenance Articles 0 04-26-2002 08:00 PM
Loose Cutlass Bearing Sue & Larry Gear and Maintenance Articles 0 02-18-2002 07:00 PM
Cutlass Bearing Query SailNet Gear and Maintenance Articles 0 06-06-2001 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
