PSC 37 Purchase related questions - Page 2 - SailNet Community
post #11 of 22 Old 08-03-2007 Thread Starter
That would be the boat. May have hit a snag in negotiations, though. In the mean time, I will be looking at some other candidates.
avalauncher is offline
post #12 of 22 Old 08-03-2007
Sometimes a Member
Engine Hours
I don't think you're that far off base ... I usually buy 20-30 year old boats so I have a different perspective.
Sailboat diesels often don't go more than 2000 hours between overhauls. This is NOT because the diesels have a short life, but because it often takes decades to accumulate that many hours. Despite their high revs, these small diesels are NOT highly stressed motors, and if run a lot (at a reasonable load - say 65% - 80%) are likely in better shape than if barely run at all.
Sorry about my goof, assuming that the boat had been run for 2 years, not three. Around here, light use is considered to be 1/2 to 1 day of sailing a week. Generally that adds up to about 1-2 hours a week on the engine. Maybe your area requires a lot more motoring.
If the wind is up, I run the motor about 30-45 minutes total - just to get in and out of the marina and the inner harbor. But, when I was cruising last summer, I had several days when I needed to get somewhere and there was no wind. On those days, I ran the engine 8-10 hours a day. Had I been home, I wouldn't have been out on those days.
As to whether a surveyer will look at sails, if the mast is up and the sails are bent on, they can give you a reasonably educated opinion, which should be enough. BUT, if the sails are bagged, my experience after 3 purchases is that they will pull out a corner and say "I can't really tell you about the whole sail, but the corner of this sail looks new/decent/worn/dead".
This isn't bad, but an in-depth inspection will tell you more. I've experience all of the following: the spreader patch is in the wrong place and the jib is being damaged; the sail has been exposed without its cover and one part of it is rotted; or the sails don't match the inventory. Of course, all of this is less likely on such a new boat.
A sailmaker around here would probably charge around $100 - $200 to give a full set of sails a once-over. You could call one and ask, but given the overall perspective of the cost of the boat, it may not be worth the time and effort. A new main and jib for your boat would be in the ballpark of 4-5 k from a big name sailmaker, and I doubt that the sails are completely worn out after three years in the Chesapeake area, so it's not anywhere as big a deal as the engine.
I don't know of any other specialists, but I would also talk to the owner or techs at the yard that has been servicing the boat. You should ask for the service records if they have them. Obviously, if the owner had done all his or her own maintenance, then this information won't be available.
I do have a couple of other suggestions:
You should absolutely insist on a sea trial. It is good to have the surveyer onboard for the sea trial, if you can get it arranged. It is also good if you can get the owner to come too, as he or she will know how the rigging should be set up and what the quirks are. A couple of hours with the owner can save you a lot of puzzlement later on.
Also, before the survey, I would go over the boat and take notes as to any questions you may have. I would also follow the surveyer around with a notepad and feel free to ask any reasonable questions that come to mind.
It is good to remember that surveyers, mechanics etc. are not omnipotent, and can miss things. You are cutting down on surprises, but cannot completely eliminate them. For example, I had a worn shaft coupler and shaft, due to prior engine mis-alignment, which in turn had been due to a motor mount adjusting nut vibrating loose (not a PSC issue). Neither the mechanic nor the surveyer spotted this, and it was not discovered until I had had the boat for a year.
This repair required a new shaft and coupler (about $500) and since the rudder had to come out to pull the shaft, I combined this repair with replacing the worn out cutlass bearing.
richnren is offline
post #13 of 22 Old 08-03-2007 Thread Starter
Excellent advice, thanks alot.
post #14 of 22 Old 08-08-2007
Moderator
JohnRPollard's Avatar
Avalauncher,
Engine Hours: Just to give you additional perspective, when we bought our 13 year old PSC Crealock 31, it had about 650 engine hours on it. After five seasons of using the boat quite a bit on the Chesapeake, we've added about 200 hours.
Scheel Keel: Most owners seem happy with it. But they do not have the same amount of ballast (I think the spread is only about 200lbs on the 37, though). I've also heard, anecdotally, that the draft for both keels is greater than the figure listed in the spec. Which might explain why most choose the scheel keel.
If you have further questions about the 37, you should post them over on the list-serve where there are many owners:
http://list.sailnet.net/read/?forum=pacificseacraft
JohnRPollard is offline
post #15 of 22 Old 08-09-2007
Avalauncher,
Back to your original question on pros and cons of a Scheel Keel, the following article might be helpful.
http://www.ventureyachts.com/ph40shoalkeel.html
TejasSailer is offline
post #16 of 22 Old 08-09-2007 Thread Starter
Gee, and here I thought the name of the keel was a combination of the words shoal and keel. Who'd a thunk it was the designer's name.
post #17 of 22 Old 08-09-2007 Thread Starter
But, from reading that article, I would be swayed to believe that the Sheel keel may sail better in all circumstances. Why, then, does the deep keel outperform when sailing to wind?
post #18 of 22 Old 08-09-2007
Sometimes a Member
Perhaps we just assume that it does!
I haven't directly compared keels, but I don't feel that my Scheel boat is close-winded. It is, however, plenty competent for cruising. I have no safety concerns about the keel whatsoever.
richnren is offline
post #19 of 22 Old 08-09-2007 Thread Starter
Pan Interior
Well with my other questions answered, what about the "pan" interior. I've a number of criticisms of this construction method - not as strong, or as quiet, prevents access to inside of hull.
Any comments from existing owners? Are the criticisms valid or is this of little or no concern?
post #20 of 22 Old 08-10-2007
Sometimes a Member
I'm going to take a pass on commenting on the "pan" interior, because I don't have any specific information. However, everything I've seen PSC do, they've done right.
richnren is offline
PSC 37 Thru Hull Quick Reference arisatx Pacific Seacraft 1 04-05-2008 07:06 PM
boat purchase, taxes, residence -- help for NW sailer? winslow59 Boat Review and Purchase Forum 15 01-14-2007 10:20 PM
Questions about boat buying process... slimqs Boat Review and Purchase Forum 7 03-27-2004 12:07 PM
New X-46 -- New Intro -- First Questions John-A Boat Review and Purchase Forum 8 01-29-2004 08:21 PM
a few specific design questions jbarros Boat Review and Purchase Forum 5 10-02-2003 02:13 PM
HTML code is Off
