Blogs
Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
User Name
Old 10-18-2007
SVArgo SVArgo is offline
S/V Argo-Pacific Seacraft
SVArgo is on a distinguished road
Mast Paint
I'm doing some touch up work on the mast, scraping off some corrosion and re-priming and painting.
I have a tiny amount of paint labelled "eggshell white," I'm assuming that this is the mast paint. I have some others for the deck and the topsides.
The question is, does anyone know what type of paint this is, polyurethane, epoxy, etc. and if there is a comparable and compatible product out there (US Paint, Interlux, etc.) and if so, what part number?
Thanks,
Ryan
Ryan Roberts
S/V Argo - Pacific Seacraft 37 Hull No. 349
Old 10-19-2007
sailaway21's Avatar
sailaway21 sailaway21 is offline
gadfly
sailaway21 is a jewel in the roughsailaway21 is a jewel in the roughsailaway21 is a jewel in the roughsailaway21 is a jewel in the rough
Uh, does it say anything else on it other than just "egg-shell"? Do we have any indication that this is not something left over from last year's repaint of the dining room at home? (g)
Liberalism: the haunting fear that, somewhere, somehow, someone can help themselves.
Old 10-19-2007
There were three sets of paint, one was the deck, one was the hull, and one was the "eggshell white" The owner said the mast paint was in there, so I can only deduce that that is it. I could be wrong, but that's all the information I have to work with at the moment. It looks to be a two part paint.
Ryan Roberts
Old 10-19-2007
Sapperwhite's Avatar
Sapperwhite Sapperwhite is offline
Not So Senior Member
Sapperwhite has a spectacular aura aboutSapperwhite has a spectacular aura aboutSapperwhite has a spectacular aura about
Give the PO a call and confirm which is the mast paint. Once it's up, you'll have a hell of a time painting the mast from a bosuns chair.
Dictated, but not read.
Old 10-19-2007
Yeah, I got the paint and the specs, its a two part polyurethane, I'm just not sure what aftermarket prodcuct is similar.
I agree that I don't want to do any of this from a bosun's chair.
Ryan Roberts
Old 10-19-2007
While the mast is down, take pictures and measurements of all the mast head gear. Also, you should double check the nav lights and write down what bulbs you need to keep on hand for spares. Maybe hit all the moving parts and sail track with some Sail Kote or similar.
Old 10-19-2007
camaraderie's Avatar
camaraderie camaraderie is offline
Moderator
camaraderie has a spectacular aura aboutcamaraderie has a spectacular aura about
Awlgrip makes an eggshell white and it is a 2 part...my guess is that is it.
http://www.marine.com/product_info.php/products_id/153
Old 10-19-2007
Sapper,
That's all in the plan. Luckily, the prev. owner still has all the original documentation from the factory with parts lists on bulbs, etc. very good stuff.
I've got two huge cans of McLube ready for the task.
Ryan Roberts
Old 10-19-2007
Camraderie,
I think that you're right, its got to be close. I would imagine that the factory would have been buying something commercially available such as Awlgrip.
Thanks,
Ryan Roberts
Old 10-19-2007
sailaway21's Avatar
gadfly
(most factories do buy something commercially available!) (g)
Display Modes
vB code is On
HTML code is Off
Deck stepped Mast-Always Bad ? Mrs Mutiny Buying a Boat 24 02-01-2008 10:05 AM
Southern Cross 31? db27513 Buying a Boat 35 09-24-2007 10:58 PM
30ft Catalina BigRuss Buying a Boat 3 09-09-2006 05:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
