Blogs
Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
User Name
Old 01-31-2007
Granuaile Granuaile is offline
Granuaile is on a distinguished road
Marine Tankless Water Heaters
Fellow Sailors,
Does anyone have practical experience with or knowledge of the use of marine tankless water heaters? I'm a Great Lakes sailor and have no pressing need to have hot water while underway, but would like to have it in port. I've been looking at an EEMAX Marine Electric Tankless Water Heater. Your comments are appreciated.
Jim
Granuaile
PSC '34
Old 01-31-2007
PBzeer's Avatar
PBzeer PBzeer is offline
Wandering Aimlessly
PBzeer has a spectacular aura aboutPBzeer has a spectacular aura about
Granuaile, there's a recent thread in the Gear & Maintainance forum on this topic, though no one really addresses the electric ones. I was looking into them, but it seems they don't make the water that much hotter than what is in the water tank, judging by the literature. They cite x number of degrees above the ambient temp of the tank at 1gpm.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
Old 01-31-2007
billangiep's Avatar
billangiep billangiep is offline
billangiep is on a distinguished road
Jim,
I have been considering this one....... http://www.excelamerica.com/calentadores_eng.htm although I have no first hand experiance . My Yanmar is raw water cooled hence no hot water tank. The sun showers are getting old !!
Bill,
Old 12-18-2007
rsford rsford is offline
rsford is on a distinguished road
I had one installed on a Pacific Seacraft Orion back in the late 80's. It was a very attractive Webasto stainless unit that mounted in the cabin on a bulkhead. It ran on propane and had a very nice stainless chimney that went up through the cabin house. It worked great for hot showers and hot water in galley and easily got the water hot enough to burn the skin if not careful -- you had to mix the output with cold water and get it flowing just right before hopping in. Then there were some press reports about a very well known woman sailor who died from carbon monoxide from such a unit -- I think I recall that hers was mounted in a small head. Seems like a CO-detector could have prevented her death, but I never saw much advertising for instant hot water heaters for boats after that. I sold that boat a couple of years later, and my next boat was a 37 which has a regular hot water heater system.
Old 12-18-2007
Gryzio's Avatar
Gryzio Gryzio is offline
Spam, Food of the Seagods
Gryzio is on a distinguished road
Red face I just offer what I know, not much
First, I always feel we need to understand how something works, if, we going to buy and use it.
This link show a simple on Hot Water Heaters;
http://home.howstuffworks.com/water-heater1.htm
Now, once we see the concept used (Very Basic) then we can move on to a faster version, the tankless.
I have worked on these before, both in home use and commercial use. BIG 1,000 gallon tank with this small Instant heater not much larger than a house unit. How this commercial unit worked with the use of circulating pumps and as the Large tank cooled the small unit heated the water as needed. I worked directly with the Manufacture for a City Unit as this was "new school" to myself.
I wanted to find you a picture, maybe later or someone else can. But, in the link I give you see the water tank? What they do is Coil a pipe for the water to replace the tank. As the water flow through the coil it becomes heat by Flame/electric (You can even use Solar or I can and will try to explain this later). As mention already, we know Fire can be dangerous (Proper ventilation stuff as fire needs oxygen to burn). Electric may not heat as efficient as Fire (Any flammable gas or wood will make fire). The electric is more safe as it not produce CO2 or burn up the oxygen as a fire will.
OK enough on basics, you can learn from there and may already know all this.
For the heater to work we have to provide time to heat. This why we not use just a straight pipe as the water not in the Fire/Electric long enough to heat, so, we coil this. A putt-putt boat is a good example (A toy many made as a child). So, not sure I going to answer your question, but, electric not seem to be a very effective heat source for hot water, unless you running a generator or on shore power. I like hot water when I off those life-lines.
Here how I did this.
I had 20 acres of land and it was far from a Fire Department. I tell everyone, Have enough water hose to reach where you need. I bought a 100' "Black" rubber hose. When I would be clearing my land, I make a brush pile to burn and have my hose close with water faucet on and a sprayer on the end to turn off and on. What I noticed was when the water was off, in full sun. it became hot inside the hose and when I turn it on it stay hot until the cold water from the faucet push the hot water out. Well, that how those House Roof and Tankless Hot Waters work! So, I had to do some math. Depending on my inside hose diameter, how long of a hose did I need for a specific amount of hot water before the cold come out?
Now, I can lay a 100' "Black" rubber hose (Green may work) on top of my boat and have enough hot water, but, this not too efficient with a hose running everywhere to trip over. Years before all this I had done a research paper in college on Solar Ovens (Way before people ever heard of these, I have mentioned for the women here, I not old, I am 35 and been 35 for 15 years ). When I coiled my hose and put it inside my Solar oven it became a small version of the Tankless Hot Water Heater! We see this concept on the top of a house, it inside a sheet of glass or whatever!
Now, this not the best water heater, as mentioned a person need to know how hot and adjust the cold water.
My Camping Trailer help some. When on a contained water source (Maybe 30 gallons) I learned to conserve water. So, when taking a shower I used a hand sprayer and wet myself and turn off the water. Soap up and then turn on the water to rinse. I not sure of others here, but, I do the same on a boat unless I on a life-line to shore.
So, my little garden hose work for me and it not have such a pressure increase as to worry with a release valve as we see on some applications.
Well, I not sure I help you, but, sometimes want to interject other ways we can approach the situation. I will assume the Electric you mention will work, but, it up to you to decide the cost against other alternatives. Good Luck and maybe one day we run into each other in the open sea. "Ramming Speed"! LOL!
All the rivers run into the sea, yet the sea is not full.
Ecclesiastes, 1:7
Display Modes
vB code is On
HTML code is Off
Water, Water Everywhere Tania Aebi Cruising Articles 0 06-14-2004 08:00 PM
Watermakers Don Casey Miscellaneous 0 02-01-2004 07:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 07:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
