Originally Posted by Beattie
Hi John,
I too have a PS31; any chance you could send me a picture of the Dickinson Heater installation on your boat?
Many thanks.
Richard Beattie
Hi Richard,
If you own a 31, then you are well aware of the dilemma when it comes to bulkhead-mounted heaters: No bulkhead!! I struggled with this problem for quite a while. I saw one guy that installed his on top of the galley cutting board, which was okay but not ideal in our view. Another boat put it on the forward side of the galley drawer area, next to the trailing end of the port settee. That wasn't ideal either.
Then I saw a photo of this boat:
This guy essentially built out the forward bulkhead on both sides, mounting a heater on one side and a bookshelf on the other. I basically copied this approach, but only on one side, leaving the other side open as it is normally. I chose to build-out the starboard side and mount the heater there, primarily because I found it easier to run the propane to that spot.
Unfortunately I do not have a good photo handy of my installation. It is similar to the one you see in the photo above, but on the starboard side, and also we used the Newport Dickinson (same as SailorTJK's further above) heater rather than the smaller Force 10 you see immediately above (by the way, I strongly advise against that Force 10 (now Sigma) heater, as it doesn't have many of the advantageous features of the Dickinson).
Happy to answer other questions if you have them.
