Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 07-29-2008
plittman is on a distinguished road
starting engine
I have a 1998 PSC with a 3jh2 yanmar engine. While at dock in St. Martin I experienced difficulty starting the engine. It had not be used for several weeks. It turned over fine and after several attempts it finally started. This did not happen again and never happened before. Any ideas?
Phil Littman
Old 07-29-2008
erps's Avatar
the pointy end is the bow
Intermitent problems are the hardest to figure out. Does it have a "kill cable" to shut off the engine? (diesel). If so, maybe the kill cable was still slightly in the stop position, shutting the fuel off at the injector pump.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 07-29-2008
LittleWingCA is on a distinguished road
Have you checked any of the following:
Dirty primary fuel filter?
Dirty secondary fuel filter?
Water / Moisture in the fuel?
Bacterial growth in the fuel tank?
Loose fuel hose clamps that might allow air into the lines?
Dirty Injectors?
There could be a lot of reasons. What is the history of your engine maintenance program, and did you recently do anything new like add new fuel to the tank or change climates where bacterial growth in the tank could have started?
LittleWingCA
1980 Pacific Seacraft Orion 27
Sailing Grounds: Southern California
HTML code is Off
Bleeding your Yanmar Engine artbyjody Gear & Maintenance 31 03-22-2012 02:36 PM
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
