Outboard Motor Mount for PCS 34, 37, etc. - SailNet Community
post #1 of 5 Old 12-21-2008 Thread Starter
S/V Argo-Pacific Seacraft
SVArgo's Avatar
G'day all,
I'm trying to determine what the best mount for an outboard (Honda 5HP) is going to be for a Pacific Seacraft. The white plastic block ones wonlt seem to work as none of the stern rails and stanchions intersect at a 90 degee angle?
What does eveyone use and / or recommend and are there any particular lessons learned?
Thanks, Ryan
Ryan Roberts
S/V ARGO - Pacific Seacraft 37 Hull No. 309
SVArgo is offline
post #2 of 5 Old 12-21-2008
Coastal Carolinas
Norstar's Avatar
Ryan,
Check out the Edson model 100ST stern rail mount for 1" rails. Its on the pricey side but the right tool for the job and your 37 is worth it!!! They are functional and look great on the back of any boat. You can check it out on their site at Edson Marine.
John Schwab
"Norstar" PSC 34 #201
Norstar is offline
post #3 of 5 Old 12-21-2008
arisatx's Avatar
Ryan:
I agree with Norstar. I mounted an Edson on my stern pulpit as you can see in the photo below. I wanted it to hang plumb, so I fabricated a short piece of starboard as a standoff between the cleat and the Edson.
This required I obtain some longer hardware - 18-8 SS Flat Head Phillips Machine Screw 1/4"-20 Thread, 6" Length, from McMaster Carr. I didn't want the hardware to protrude on the back side, so I countersunk it as you can see below.
I can get my Mercury 6hp 4stroke up there manually, but would love to have a crane someday.
Here is the link to Edson.
Regards,
Ted
V42#186
s/v Little Wing
arisatx is offline
post #4 of 5 Old 12-21-2008
moderate?
camaraderie's Avatar
Sorry to butt in on this but just a note for any others who may be reading...this Edson motor mount ALSO comes in a size for 1.25" rails and I believe is the ONLY motor mount which does so. Expensive and excellent as John/Ted says.
camaraderie is offline
post #5 of 5 Old 12-22-2008
lsbrodsky's Avatar
I solved the rail problem by inserting a short piece of stainless tubing in the vertical cutout in the motor mount. I put a rubber cap on it and adjusted the length of the tubing so that the rubber cap rests on the lower rail. Cheap and looks fine.
Larry
ASYLUM
lsbrodsky is offline
Outboard Mount and the transom of a Cal 20 lostcoast Cal 9 03-04-2013 12:26 PM
Outboard motor controls waltzingmatilda Gear & Maintenance 3 05-05-2010 09:08 AM
Reputable websites from which to buy outboard parts? Chompy Gear & Maintenance 4 05-04-2010 02:41 PM
Inboard vs. Outboard greencaptn Boat Review and Purchase Forum 19 02-20-2007 08:05 AM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
HTML code is Off
