Installing a new windlass - SailNet Community
Blogs
Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 12-29-2008
samchristo is on a distinguished road
Our old Muir windlass gave up a couple of weeks ago and we bought a new one thru the PSC factory. Their price for a new Muir was the same as the lowest I found on the Internet and they built a new pad and backing plate for a reasonable fee.
The new pad is for the new Muir design, hence I need to remove the old teak pad. This is not a trivial task, I've found.
Anyone have any ideas for removing blocks of teak glued to the deck ?
Thanks,
Sam
sv Grace PSC34 #163
PS - if you use a PSC pad have them build the new pad considerably larger than the one for the new boats. It will be easier to hide the old holes, etc with a much larger pad.
Old 12-30-2008
Sapperwhite's Avatar
Not So Senior Member
Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about
When I replaced my bowsprit I used Debond, a heat gun, some metal bladed putty knives, and some small plastic timber wedges.
Warm the joint with a heat gun, then spray some Debond on and let it sit awhile. Then use the metal blade putty knife to start breaking the joint. It may take a few passes around because you will be exposing "new" bonded sealant as you make your way deeper under the pad. Tap the plastic timber wedges into the joint as you go around and leave them in. They will provide constant pressure to break the seal.
I did this and got my bowsprit up with only a very small patch of gel coat coming up from the surface right in the middle of the project area. I admit that was my fault, I got a little excited as I saw the results.
It's not that hard and cheap to do if you are handy.
Here is the Debond link, this stuff is crucial:
Debond Marine Formula
Dictated, but not read.
Old 12-30-2008
Kailani33's Avatar
Kailani33 is on a distinguished road
Sapperwhite is right about the puddy knife and wedges. Since I didn't have any Debond, and since I had been warned to keep PB Blaster away from rubber parts, I got the idea to try PB Blaster. After breaking the edge seal with a putty knife, I let PB Blaster soak into the sealant. When the seal started to let go, the whole piece came off and no gell coat was pulled off.
HTML code is Off
Installing an anchor windlass GoodOldBoat Gear and Maintenance Articles 7 02-24-2011 11:22 PM
Installing an anchor windlass GoodOldBoat Gear and Maintenance Articles 1 08-26-2007 08:03 PM
Choosing and Installing an Electric Windlass Sue & Larry Gear and Maintenance Articles 0 09-06-2002 09:00 PM
The Great Windlass Debate SailNet Seamanship Articles 0 11-30-2001 08:00 PM
The Great Windlass Debate SailNet Gear and Maintenance Articles 0 11-30-2001 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
