Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
  #21
Old 11-14-2012
MarcHall is on a distinguished road
Re: Autopilots on PSCs
Bill
The WH Autopilot I installed on Crazy Fish has an stout arm that mounts/clamps to the rudder post below the quadrant. The end of this is attached hydraulic actuator that is mounted starboard bulkhead which I beefed up using a piece of 2x6 and fiberglass.
Currently what WH calls the RAT which provides the feedback on the rudder position which is lightweight device is attached to the quadrant. When I convert the boat from wheel to tiller I will have to come up with something else.
I assume from your post that on your boat there is a fiberglass column surrounding the rudder post thru the engine/below decks compartment and
that you will need to cut thru it to gain access. Would seem that the bearings
for the rudder post would be located where the post comes out the deck and
in the hull so completely removing his fiberglass column would be fine.
Might call Thumper at the factory to see what they would do if converting the boat from tiller to wheel or just adding a below decks autopilot to a boat configured as yours. He has been pretty helpful working with me on the wheel to tiller conversion.
Also couldn't be happier with the WH Autopilot that I installed ~1998. The unit just continues to work. My first issue occured a couple of months ago when the remote control stopped working. There was some corrosion
around the buttons, etc. I sent it in and for $160 they overhauled and ship it back to me.
Marc
Crazy Fish, Crealock 37, Hull 207
  #22
Old 11-30-2012
Capt. Grimek is on a distinguished road
MC1, I sent you a PM but just in case...did the factory have any objections or concerns at all, about the removal of the aft bulkhead for access to the steering cable/reel? Seaworthiness, etc.?
I've thought about doing something similar or at least a big access hatch but wasn't sure
about reducing the strength of the stern area for offshore.
Thanks! Jim
  #23
Old 12-02-2012
MC1 MC1 is offline
MC1 is on a distinguished road
Thanks! Jim
Did you mean 'DGriffith' instead of MC1? I didn't have to do any bulkhead modifications on my PSC '34.
  #24
Old 12-03-2012
Oh, sorry! Yes, I was referring to the owner of the 31.
Been a bit muddled with family/hospital stuff and two boats!
Thanks, Jim
  #25
Old 12-09-2012
s/v Pelagic
jnewcomer is on a distinguished road
If you have a Monitor you could try this.
As has been described by others, we hooked up an ST1000 tiller pilot (actually an Autohelm 800 initially) to our Monitor wind vane. This solution works while sailing or motoring. Hans at Scanmar says the prop wash while motoring is hard on the Monitor but we haven't noticed any problems.
We upgraded our installation two years ago to include the Raymarine S100 remote control so we can tweak the course without having to push the buttons on the ST1000. We also put a three-bladed prop on which reduces the prop turbulence on the Monitor.
If you are interested I could send some pics or more info.
John
s/v Pelagic
1980 C37 Yawl #22
You may post attachments
You may edit your posts
Member reviews: Raymarine's X series Autopilots artbyjody Gear & Maintenance 14 08-02-2011 07:44 AM
experience with Navman autopilots patrisage Gear & Maintenance 2 08-26-2009 09:06 AM
Autopilots and Windvanes Paul & Sheryl Shard Cruising Articles 0 06-17-2002 08:00 PM
SEO by vBSEO 3.6.1
