02-25-2009
Batmon
Originally Posted by billbalme
I have Toodle-oo!'s wiring all pulled apart. It's 25 years old and resembles my wife's spaghetti. Rewiring the main panel looks to be a relatively straightforward job, but I'm having problems with the charging circuit and wonder what everyone else is doing.
The boat has Ample equipment mostly: Eliminator, Alternator Sensor and Monitor. It has an Alpha 3 Cruising Equipment Alternator Regulator and she has an old Heart Interface 1800 inverter.
The Ample (Bank Manager) Monitor is not working properly - basically I only get volts and some weird numbers for everything else...
I'd like to replace the Bank Manager with something else - but leave all the rest of the equipment alone. Other than a Xantrex 20, I can't find any other monitor out there that could handle this - and apparently Ample aren’t interested in assisting with the existing unit or supplying an alternate...
(I thought I was going to go with a Xantrex 2000R until I found out I'd need to replace the inverter too to be compatible...)
Other system components: 400AH Battery bank + Starter battery, 90A Alternator, frustrated owner!
What's in your charginging circuit?
Bill
S/v Toodle-oo!
PSC 37 #148
Bill, I completely redid my charging circuits a couple of years ago. I replaced the on/off/both switch with individual start and house switches with a crossover. I also installed a Xantrex Battery Monitor. Works great.
I haven't looked in awhile, but there used to be several brands out there, but they were all basically the same in function and price. I don't know about reliability.
John
PSC 34' '91
