Converting a water tank to diesel?? - SailNet Community
post #1 of 3 Old 05-05-2009 Thread Starter
Pete & Carol Bailey
Bali Blue is a PSC40, hull no 54. We opted for 3 water tanks (465 l) and one diesel (265 l).
Can anyone offer practical advice on converting the aft water tank to diesel?
Pete & Carol Bailey
Pete & Carol Bailey
SY Bali Blue (Pacific Seacraft 40)
BaliBlue is offline
post #2 of 3 Old 05-07-2009
ralopata's Avatar
Hello, Pete:
I'm not sure the aft tank would be suitable without modification (I'm not on the boat right now, so I'm working from memory...). I believe the top of the tank onboard JUNO (PSC 40 -- #46) is either plexiglas or Lexan, which I don't believe would be usable with diesel. So, at the very least, you'd have to install a new tank top.
I believe the bottom and sides of the tank are fiberglass, which, I think, would work, but someone with greater knowledge could probably advise you.
On JUNO (PSC 40 -- #46), the number 2 water tank, located beneath the sole aft of the galley, is stainless steel. Stainless can be used for diesel tanks, but I've read it has pros and cons (Some say it's great; others say the welds are subject to corrosion and will ultimately fail). But that tank might also be a possibility.
On 40s that were equipped with a dedicated second diesel tank, it was located beneath the dinette seat just forward of the galley, which put it quite close to the primary fuel tank, and there was a manifold installed there to control the feed of the two tanks. If you are willing to give up some storage, this, too, might be a possibility.
Perhaps one of the 40 owners who has a factory-installed second tank will weigh in.
Hope this helps a bit.
Fair Winds,
Roger Lopata
JUNO
PSC 40 -- #46
(Still on the hard in Rock Hall, MD, but hoping to finally splash the boat tomorrow and start commissioning...getting a very late start this year)
ralopata is offline
post #3 of 3 Old 05-08-2009
Pete, That is an interesting use of that tank. I would think you could have a bladder made to fit the tank. That would make the PSC boats real long range cruisers and avoid jerry jugs on deck. Makes me rethink use of that tank. Doug Griffith PSC37 #249 Kindred Spirit.
DGriffith is offline
Diesel fuel tank cleaner recommendations? BELLATRIX1965 Gear & Maintenance 1 03-29-2009 06:51 PM
Smaller diesel tank. L124C Gear & Maintenance 3 11-29-2008 12:08 PM
Flexible Water Tank? davmarwood Gear & Maintenance 5 06-19-2008 07:35 AM
Water, Water Everywhere Tania Aebi Cruising Articles 0 06-14-2004 08:00 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
HTML code is Off
