PSC cockpit shower replace - SailNet Community
post #1 of 5 Old 05-28-2009 Thread Starter
My PSC 32PH (#15) has a Grohe laundry-type faucet (manufactured 1992?) controlling a cockpit shower. The 1/2’’ shower line attaches directly to the unit via a 1/2’’ x 3/4’’ reducer (i.e. there is no spout). Internal pipes were imperfectly drained last winter…froze…ruptured the whole unit. Now similar size faucets are widely available except that they all have spouts that attach to the base with an oddball >3/4” thread. There does not appear to be any anything manufactured to connect this thread to standard hose 3/4” or 1/2”. There is not space to use a unit with an attached hose-threaded-end-spout. Any suggestions how to solve this?
Thanks, DH
PSC 32PH 'Drift'
Drifting is offline
post #2 of 5 Old 05-28-2009
Mondofromredondo
I haven't a clue how to advise you but you might find alot more people looking at this one which really isn't a PSC issue so much if you were to post in another of the forums. I'm about to start a cockpit shower project as I know how sweet it would be to have the shower out there instead of inside that tiny little head.
Good Luck !
Keith
mondofromredondo is offline
post #3 of 5 Old 05-29-2009
Moderator
JohnRPollard's Avatar
Good Luck !
Keith
If you go forward with that, make sure the cockpit shower hose is long enough to reach a swimmer while standing on the swim ladder (for a quick rinse before boarding). Ours is just slightly too short and I will swap out the hose one of these days.
JohnRPollard is offline
post #4 of 5 Old 09-30-2009
Wing n' Wing
cockpit shower
Where are you located?
There is a hardware store in Bellingham, WA that stocks, and can convert any threads known to man.
Lansdowne is offline
post #5 of 5 Old 09-30-2009 Thread Starter
Cockpit shower solved
Thanks for your tip, Lansdowne - however, after visiting numerous plumbing supply houses I found a Waltec utility faucet that approximates the original supply thread. This has been in use for several months without leaking...
Drifting is offline
cockpit cushions for PSC 34 Lstiles Pacific Seacraft 2 01-08-2007 04:35 PM
The Cruising Cockpit Sue & Larry Buying a Boat Articles 0 07-08-2003 09:00 PM
The Cruising Cockpit Sue & Larry Gear and Maintenance Articles 0 07-08-2003 09:00 PM
The Cruising Cockpit Sue & Larry Cruising Articles 0 07-08-2003 09:00 PM
The Cruising Cockpit Sue & Larry Her Sailnet Articles 0 07-08-2003 09:00 PM
HTML code is Off
