Friedrich Grohe Galley Faucet - SailNet Community
Blogs
Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 06-06-2009
stevemac00 is on a distinguished road
I'm looking for suggestions on how to get more pressure out of this faucet. I've taken it apart as best I can to soak, de-lime and clean but it's still weak. Can parts be obtained for this faucet? My wife likes it so we'd really like to salvage it and make it useful.
Steve
PSC 31 #84
Talisman
Old 06-07-2009
Drifting is on a distinguished road
I have weak flow from my galley Grohe, probably a Ladylux 1 (discontinued). Possibly due to the one-way valve spring at the base of the pull-out nozzle being too strong for the water pressure. If you really want more flow, you might drill out the valve – and then in future avoid dropping the nozzle in sink water.
A distributor suggested parts might be available through Grohe at 1-888-644-7643 (I haven’t tried this).
By the way, I get sufficient water with a foot pump via a Nature Pure filter (same as Seagull IV).
Drifter
PSC 32 PH #15
Old 06-07-2009
badsanta is on a distinguished road
are you sure it is the valve? any way to disconnect the faucet and check the flow out of the supply lines? Clog, kinked line of pump outlet. just a thought
That derelict boat was another dream for somebody else, don't let it be your nightmare and a waste of your life.
HTML code is Off
The Well-Equipped Galley Kathy Barron Cruising Articles 0 11-04-2000 08:00 PM
The Well-Equipped Galley Kathy Barron Her Sailnet Articles 0 11-04-2000 08:00 PM
Renovating the Galley Sue & Larry Gear and Maintenance Articles 0 07-12-2000 09:00 PM
Renovating the Galley Sue & Larry Cruising Articles 0 07-12-2000 09:00 PM
Renovating the Galley Sue & Larry Her Sailnet Articles 0 07-12-2000 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
