Sea Gull Filter - SailNet Community
Blogs
Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 06-06-2009
stevemac00 is on a distinguished road
Sea Gull Filter
I know some of you have this installed. I bought one this year and looking for suggestions on installation. I foolishly hooked it up in line with the gusher foot pump but there's just not enough pressure. I'd like to avoid a third spout on the small sink. Did you install it inline with the main faucet?
Steve
PSC 31 #84
Talisman
Old 06-06-2009
bjung's Avatar
bjung is on a distinguished road
Steve,
That's the same way the filter is installed on my boat, not much pressure here either, but enough to get the water I need.
Bernd
PSC 31 #83
Old 06-07-2009
Wish I'd done better research instead of relying on faulty intuition. In case anyone else has this question downwind...
The Whale Gusher galley pump always seemed like it had a lot of pressure but according to Whale it has a discharge head of 10 feet - which converts to about 4.5psi. The Sea Gull filter requires a minimum of 30psi.
The Shur-Flo main water pump is 45psi. The Grohe galley faucet cold water comes off the Tee immediately down from the pump so I inserted the Sea Gull inline there. All cold water at the galley is filtered which is a downside but there's plenty of pressure to get through the filter. The filter is rated for 1000 gallon.
Steve
PSC 31 #84
Talisman
Old 06-08-2009
lsbrodsky's Avatar
lsbrodsky is on a distinguished road
Bernd,
Glad you joined this forum!
Larry
Old 06-08-2009
badsanta is on a distinguished road
Mine is connected to the pressurized fresh water system. It is connected to a tee on the cold water side below the sink.
That derelict boat was another dream for somebody else, don't let it be your nightmare and a waste of your life.
Old 06-09-2009
arisatx's Avatar
arisatx is on a distinguished road
I put ours downstream from our galley foot pump. Not a copious flow, but good enough for us. The SeaGull really does a nice job.
Regards,
Ted
V42#186
s/v Little Wing
HTML code is Off
In Search of Sea Room Micca Hutchins Seamanship Articles 0 03-26-2002 08:00 PM
Sea Snakes Ralph Doolin Seamanship Articles 0 01-21-2002 08:00 PM
Sea Snakes Ralph Doolin Cruising Articles 0 01-21-2002 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
