Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 06-26-2009
cvsheppard's Avatar
cvsheppard is on a distinguished road
PSC 34 Engine Mounts
If any PSC owners have ever changed out their engine mounts, would you kindly share your experience with me. What vendor and type mount did you use, and if you changed it yourself (which I'm hoping to do) how did you raise the engine? Did you have to disconnect the transmision? Are there any other details one should know.
Thanks,
Carl
s/v Credence II
PSC 34 # 159
Portland, Or.
Old 06-26-2009
r.furborough is on a distinguished road
Engine mounts are more specific to the engine than they are to the boat. What engine does your boat have fitted?
Old 06-26-2009
cvsheppard's Avatar
You're right, I was forgetful not to add that bit of information.
I have a Yanmar Diesel 3HM35F.
Carl
s/v Credence II
PSC 34 #159
Portland, Or.
Old 06-27-2009
Redfish is on a distinguished road
Carl,
I just replaced the mounts on my Yanmar 3HM35F two months ago. I did all the work my self so I have taken the hard road, but it is well worth it. I know the procedures well and can allign the engine again with no problems. Installing the new mounts is not bad. The engine re-allignment was the most difficult part for us.
I researched the availble aftermarket mounts and decided to use the Yanmar mounts. In the end, it was an easy choice. I checked with three Yanmar distributors, a Yanmar mechanic, and my manual and all confirmed the 3HM35F uses four #100 mounts. This is important because some of the small engines used different mounts front and back. I can give you the Yanmar part # but I don't have it in front of me right now.
Please forgive me, but it is late and my wife and I have been traveling in our boat up the Tombigbee River for the last seven days to get out of harms way for hurricane season. It would take me several hours to type a proper reply to your questions. I would be happy to talk to you about my experiences and how we did things. If you would like to discuss it please send me your phone numner and I can call you tomorrow afternoon. My e-mail address is jlloftis3@yahoo.com.
I talked to several mechanics before undertaking the project. I had one mechanic flat out lie to me and try to rip me off. It will be a long frustrating processs, but I am so glad I did it myself.
John L.
s/v Redfish
1988 Crealock 34, #95
Old 06-29-2009
wsmurdoch is on a distinguished road
Four years ago I replaced the engine mounts under my 3HM35F engine. The bolt in the forward port mount had broken, we were cruising, and I was away from my more serious tools. A mechanic did most of the work; I was a watcher and helper. The new mounts were Yanmar. We separated the engine coupling and lifted the engine with a PortaPower hydraulic jack placed under the oil pan. We took the opportunity to replace the lag screws into the engine beds with new stainless screws. The re-alignment was not difficult although up/down errors were easier to correct than side to side errors especially with the relatively flexible mounts.
Bill Murdoch
Irish Eyes
1988 PSC34
Old 09-30-2009
Wing n' Wing
Lansdowne is on a distinguished road
Agreed, the Yanmar mounts are good. Not only the alignment when you change the mounts, but every time you put the boat back in the water. Very hard to get yourself to do this, but the best thing you can do for your engine.
Old 01-27-2010
jlb40514 is on a distinguished road
Change lags to bolts/nuts
I'm restoring an '86 37. Has anyone replaced their motor mount lag bolts with machine thread bolts and nuts? I'm not sure how I would get to the underside to access the nuts, but lag bolts can strip out after time.
Thanks,
Old 01-28-2010
If your lag bolts have stripped out, a possible fix is to cut four short lengths of angle iron, drill and tap one side of each for two machine screws that will hold each engine mount in place, drill the other side for two bolts or lag bolts to enter the engine bearing members from the side, then attach the pieces of angle iron to the engine bearing members. We looked at doing this on my boat. If memory serves, the forward pieces of angle iron could be thru bolted in place and the aft ones could be secured with lag screws. My old holes were good, and we just used slightly longer stainless lag screws.
Bill Murdoch
1988 PSC 34
Irish Eyes
Old 01-28-2010
niftynickers is on a distinguished road
Jeff,
If the lag bolt holes are stripped,mine were, you can drive an epoxy coated dowel into the hole and then drill a new lag bolt hole or as Bill said if the holes are OK then slightly longer lags will work.
Dianne and Chuck Burke S/V NiftyNickers C37 #139
Old 02-02-2010
My motor mount holes seem to be in good shape. I just like through bolting better than lag bolts. That said, does anybody know how long the originally installed lag bolts are supposed to be? Just wondered if previous owners have installed longer lag bolts already.
Thanks,
HTML code is Off
Solid Engine Mounts zerubb Gear & Maintenance 7 07-03-2006 10:53 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
