08-17-2009
Hi John and y'all down in NC were I long to be,
My stuffing box has decided to run hot to the touch, I suspected that it might get worse so I had all the materials on hand to repack the box.
The manual from PSC listed the flax as 3/16 for the 31 as well as the 34 & 37.
I did bring along some 1/4" just for in case. Good thing I did as the packing I removed was 1/4" and the 3/16 was obviously to small. I think they call it a "stuffing box" because the flax should not just fall into the packing nut. The 1/4 was a nice tight fit that needed to be gently pushed home with a wooden dowel.
The flax I removed appeared to be in OK shape, it was not brittle but its difficult to tell how much lubricant was cooked out. There had been, from time to time, a bit of greenish water dripping from the box which I now believe to have been lubricant.
After I finshed, I did not have time to take her for a good work out but I did keep her in gear at 2400RPM on the mooring for 10mins and all seemed to be good. I did use the Pacific Trading PTFE flax and it was nice a juicy, I also applied a generous amount of their PTFE packing lubricant to reduce friction.
This weekend I will give her a good motoring and see what happens.
It's a bit of a puzzle why after only 25 hours she decided to get hot even though she had been dripping fine, could be engine alignment but vibration is minimal. Perhaps the factory packing "dried up" as she was built in 07 commisioned in 09?
Regards,
Steve
PSC 31 #125
Ryoko
Oriental, NC
One of the two happiest days in a sailors life To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
