Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 09-04-2009
johnharch is on a distinguished road
Rudder shaft packing on a 34
I seem to be taking on a little water through my rudder shaft when motoring. Since I will be hauling the boat for bottom work and a survey this winter, I wanted to repack it while it was out. Does anyone have any tips that I should know before I start this? My biggest concern is that I can't get back to it and will have to find a very small person to do it. Access to the systems behind the engine are my biggest/only complaint about my 34, I'm just to big to get back there. I've actually been stuck down there and needed to be pulled out.
John
Old 09-04-2009
saildork's Avatar
saildork is on a distinguished road
John, You might consider posting this question on the 'Gear & Maintenance' forum, also. You might get more responses there. Sorry I can't help you with your query ...I sail a boat with an outboard. Anyway, good luck with the water ingress problem. I'm sure some of the folks here will have a solution to your problem.
Pat
Sailing isn't a matter of life and death. It's much more important than that!
Old 09-04-2009
saildork's Avatar
Pat
Old 09-05-2009
Norstar's Avatar
Coastal Carolinas
Norstar is on a distinguished road
John,
Your right about it being a very tight space. I had the same problem with water ingress while motoring and needed to repack the rudder post gland. No way could I fit back there. My wife volunteered to tackle the job. She is 5'2" and petite. She was able to wriggle her way back there and did the repair in 15 minutes. She claims it was a piece of cake. Loosen 3 bolts and lift the collar of the gland up. Pull out the old packing with a packing pic tool, install new packing and snug up the bolts. No more leaks.
John S.
PSC 34 #201
"Norstar"
Norstar Ventures, LLC
Old 09-05-2009
Thanks John,
That's exactly what I wanted to hear. Now all I need to do is find a very small person who is not claustrophobic.
Did you have the boat out of the water when you did it, or can this be donw in the water?
Old 09-07-2009
Norstar's Avatar
Coastal Carolinas
John,
We did the re-pack while in the water. The packing point is above the waterline. Thats why you only notice the leak when your undereway when the stern is squatting down in the water a bit. Best of luck on your repair. Let us know how you make out.
John S.
PSC 34 #201
"Norstar"
Old 09-07-2009
spirit2006 is on a distinguished road
Repacking rudder post
Hi:
Access back there is very difficult. I'm not a big guy but I too have been stuck and pulled out by my belt. The only time I've repacked the rudder post was when we repowered and the engine was out, but since then I have cut an access hatch at the rear of the quarter berth which gives me accesc to the post so I can tighten the adjustment. If I had cut the access port before repowering I could have repacked through it.
This is one of the few design flaws on this boat. I got the access idea from my prior ownership of a Morgan 38. Good Luck
David and Jo on Spirit
Old 09-12-2009
Thanks David, I've been thinking about doiing that and also putting an access plate in the cockpit sole. Now that I know someone else has done it and it helps, I'm pretty sure I will. I am very troubled by not being able to access those critical systems in an emergency.
My memory is getting worse every year. David, didn't I just meet you in Port McNeil?
Old 09-14-2009
RainDog's Avatar
Not Finished Yet
RainDog is on a distinguished road
I am also planning on cutting an access hatch on the quarter birth. Would live any tips, pictures, designs anyone has of the job.
Pacific Seacraft 34 #142
Seabrook, Texas
Old 09-14-2009
Sapperwhite's Avatar
Not So Senior Member
Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about
A member of the Orion Yahoo group put two bronze access plates at just the right place in the cockpit sole to get to the rudder shaft packing and in good proximity of the quadrant. if i can dig up the pics i'll post them here.
besides that, you think its bad getting into that space in a 34? try an Orion..wheeeeeew
Dictated, but not read.
HTML code is Off
Replacing Cutlass Bearing SeaDeucer Gear & Maintenance 15 04-17-2009 03:41 PM
Building a Rudder Newport 30 Armchairprotest Gear & Maintenance 5 04-07-2009 01:11 PM
Emergency Steering John Kretschmer Seamanship Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Gear and Maintenance Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Cruising Articles 0 03-08-2002 07:00 PM
