Refrigerator - SailNet Community
Blogs
Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 10-25-2009
billbalme is on a distinguished road
Refrigerator
I'm curious to know if our fridge is a standard layout or if it has been customized somehow.
Basically the layout is an Alder Barbour freezer box mounted aft in the rear half of the cold box. The front half is separated from the rear with a wall and a removable door (not in the picture).
The front section is cooled by overflow from the rear section and by active blowing of cold air from back section to front, using the second of two thermostat controls.
At some point in the fridge's history, the previous owner tried to beautify things a little by installing some plastic sheeting and using about 15 tubes of caulk! The whole thing is coming apart now and mold is ever present.
I'm thinking I should tear down the walls and start over with the main structure - probably using starboard. Does your fridge look as bad as ours?
I'm looking for suggestions on how best to clean up the fridge and make it so that it's easy to keep clean. The Admiral would love to have it lined with stainless - but I can't see how to do that - without incorporating lots more caulk! Is there a suitable paint that will withstand the environment and allow easy cleaning?
Thanks,
Bill
s.v. Toodle-oo!
PSC 37 #148
Old 10-26-2009
JiffyLube's Avatar
Grasshopper
JiffyLube is on a distinguished road
The easiest fix would be to remove as much of that caulking as possible, then use full strength bleach on the mold. Rinse off the bleach after its had time to kill the mold (a day), and re-caulk better than the PO. The box will better, but not as good as a complete redo.
Old 10-26-2009
How would one accomplish a "complete redo"?
Old 10-27-2009
niftynickers is on a distinguished road
Bill,
On NiftyNickers I installed sheet aluminum,on the sides and front to aid in keeping the box clean.It's available form any hardware store and easily installed with contact cement.Good luck,
Chuck,S/V NiftyNickers
Old 10-27-2009
That's a great suggestion Chuck - thanks. Does the layout of your box look the same as mine? Just curious...
Old 10-27-2009
Bill, the dimensions of the boxes are the same but I dont have the dividing wall that you have nor do I have the same refrig unit. We have a Technautics with a holding plate.Our freezer is a metal box attached to the holding plate and we use a length of PVC pipe with a biscuit fan to move the cold air in the box.
Good luck, Chuck ,S/V NiftyNickers
Old 10-30-2009
JiffyLube's Avatar
Grasshopper
I'd have to research a redo since I've never had that problem before. Maybe some else will provide a redo solution.
Old 04-11-2010
I'm still pondering this one - I ended up buying some shiny white Glass Reinforced Plastic with a nice durable finish - but I'm going to be left with caulking at the seams - real mildew getter stuff...
was wondering if there's a white epoxy type of paint I might be able to apply instead and came across this: HOMAX TOUGH AS TILE BRUSH-ON FINISH 720773 HOMAX CORPORATION
Anyone used this or something similar? Thoughts?
Bill
s.v. Toodle-oo!
HTML code is Off
Refrigerator jacobitesc Beneteau 4 02-24-2009 04:17 PM
refrigerator and battery drain bkw Learning to Sail 14 01-06-2008 12:30 PM
Icebox to Refrigerator offline2004 Gear & Maintenance 12 01-26-2007 05:02 PM
refrigerator insulation for a Catalina 36 Cap'K General Discussion (sailing related) 4 06-08-2005 07:47 AM
A Safe and Sound Galley Joy Smith Her Sailnet Articles 0 03-11-2004 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
