Prop on PSC 31 - SailNet Community
post #1 of 13 Old 11-10-2009 Thread Starter
Question Prop on PSC 31
For those of you with a 31, what prop do you use (2or 3 blade, folding/reversing, pitch etc). I find that as I am motoring down the ICW every boat in the world passes me by. The bottom is clean, the engine rebuilt and not very much weight on board. I can't determine why I am so slow. (Of course the problem is that we are motoring and not sailing!!!)
PSC 31 #56
mcgray is offline
post #2 of 13 Old 11-10-2009
I have a 3 blade Campbell Sailer on mine. I can do 6 knots in calm water but I am a little over pitched because I can only reach about 2900 rpm. The 2 blade Michigan that was on the boat when I bought it didn't seem quite right but I didn't have much experience with it as I changed props right away.
Adam Owens
PSC 31 Journey
adamowens is offline
post #3 of 13 Old 11-11-2009
Maxprop (3 blade). It's great for reverse, great for sailing as it feathers and no complaints underway. I have no difficulty reaching 3400 RPM. I don't like to motor but when necessary it goes about 5kt at 2400 RPM in calm water.
Steve
PSC 31 #84
Talisman
stevemac00 is offline
post #4 of 13 Old 11-11-2009
SecondWindNC's Avatar
I moved a PSC31 with a 3-blade fixed prop from the boatyard to our dock last week, and she motored comfortably at about 5.5 knots at a cruising RPM of 2400-2500. Based on the max RPM, she could be run a little harder than that, maybe closer to 6 knots at 2600 or so, but I wasn't in a rush.
Who is staring at the sea is already sailing a little.
SecondWindNC is offline
post #5 of 13 Old 11-11-2009
lsbrodsky's Avatar
I ran the stock two-blade for the full 15 years I owned the boat. It was the right size based on max RPM and boat speed. With a clean hull she did 5 knots at 2000-2200 rpm. I never saw the need for the additional drag of a 3 blade and I did not want underwater parts requiring maintenance(folding or feathering). The only real advantage I saw to a 3 blade, based on my sailing other boats, was much better response in reverse.
Larry
lsbrodsky is offline
post #6 of 13 Old 11-11-2009
teejayevans's Avatar
PSC 31 #56
I have a 2 blade, do about 5 knts @ 2400 in calm water. I feel your pain,
especially in the lower florida section with all those bridges. The problem
is your waterline is only 24', compared with those bigger boats with 36'+
waterlines, you don't have a chance. I compensated by getting up earlier.
At the risk of stating the obvious, go offshore if you can.
Tom
PS31#111 Cielo Azul
teejayevans is offline
post #7 of 13 Old 11-12-2009
31 speed
I have a two blade standard prop. My '31 runs at hull speed (6.5 knots) at 2900 rpm. I always run at that rpm under the impression it is supposed to be better for the engine.
The main is up so maybe I am getting a boost there. I should check with no wind to be sure.
John
Watermark
PSC 31 #28
wmjr is offline
post #8 of 13 Old 11-12-2009 Thread Starter
Prop on 31 and RPMs.
MIne has a three blade prop, don't know the pitch. I usually run at 2400 and on a calm day and not significant current can get 5 kts. I have never run it for long at 2900, maybe I should increase the RPMs.
mcgray is offline
post #9 of 13 Old 11-12-2009
lsbrodsky's Avatar
Any of the diesel mechanics will tell you that you will do more harm by babying your diesel than you will by running it near full load. Running it routinely at 2000-2200 is just not enough. You should think more about 2900-3100 for cruising, some say even more. In any event, your prop size and pitch needs to support that.
Larry
post #10 of 13 Old 11-12-2009
FirstSightPS31's Avatar
cruising rpm
My hull 128 has a yanmar ygm30 which was subjected to a sea trial and certified by Mack Boring.
I was advised to cruise at 2/3 maximum rpm, both by the dealer and Mack Boring.
This puts me at right around 2200-2300 rpm. I have not yet figured out what that translates in to average speed over water, as I have only been using the speedo on the gps. It appears to be in the 4.5-5kt range.
Rod Johnson
First Sight PS31 #128
FirstSightPS31 is offline
proposing to paint prop tappers Gear & Maintenance 16 04-06-2008 11:40 AM
Zincs for Sail Prop feathering prop jrbarn Gear & Maintenance 4 09-20-2006 10:40 AM
Max prop on a saildrive levenezia Gear & Maintenance 16 09-20-2006 12:07 AM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Choosing a Prop Sue & Larry Gear and Maintenance Articles 0 12-24-2001 07:00 PM
HTML code is Off
