SSB on a 31 - SailNet Community
post #1 of 9 Old 11-10-2009 Thread Starter
SSB on a 31
Anyone have a SSB on their 31 that could give me an idea about their groundplane and how well it works?
Adam Owens
PSC 31 Journey
adamowens is offline
post #2 of 9 Old 11-11-2009
I had one installed by a professional service. They used copper strips as the ground plane. There is no external plate on the boat. I get good reception using this. It was done as per Gordon West description.
mcgray is offline
post #3 of 9 Old 11-11-2009
I too did as Gordon West suggested. His suggestion was to run two, 4-inch coppper strips to a thru hull. One from the transceiver and the other to the tuner. That is all most people need. Took me about half an hour to install the strips.
windward54 is offline
post #4 of 9 Old 11-16-2009
Psc 31 Ssb
I have a factory installed ground plane. In the couple of places where I can see it, it looks like the factory used copper sheeting added to the hull lay up schedule. There are no ground plane components external to the hull.
I use a backstay antenna coupled to my ICOM M802 via an automatic tuner.
The system works great. I have never had a problem sending/receiving email via SailMail, voice or wx fax.
Walter Donnelly
PSC31 #105
WDonnelly is offline
post #5 of 9 Old 11-20-2009
teejayevans's Avatar
BTW, the 31 has a split bow anchor locker, but only comes with 1 anchor deck pipe, I would have the factory add the second one. Another option is to add the positive latches to the bilge floor access panels if you have designs on going offshore.
Tom
PS31#111 Cielo Azul
teejayevans is offline
post #6 of 9 Old 11-20-2009
Can you tell me more about the bilge floor latches? I may want to add them to my 34.
John
johnharch is offline
post #7 of 9 Old 11-21-2009
John
The 31 comes standard (or at least use to) with non-locking floor latches,
so if you get knocked over, they will fall out, and they are very heavy and
could cause serious damage to you or the boat. I don't know if they come
standard on the 34 or not, you need to ask.
Even if you don't cross oceans, it's possible to be turned past 90 degrees,
I had this happen to me when sailing off the coast of Florida, I ended up
losing my outboard and having some lose items flying around the cabin.
But at least I didn't have 30lb floorboards flying around.
Tom
PS31#111 Cielo Azul
post #8 of 9 Old 11-21-2009
I understand the need for latches, the thought of those hatches flying about in a knockdown is frightening. I've been trying to think of a good way to secure them that will still allow easy access. When I saw it mentioned that it was a PSC option, I'm got curious if I could retrofit them into mine. Do you know what kind of latches they use?
post #9 of 9 Old 11-21-2009
I think it's the "ABI Turning Lock Lift Handle", since it's bigger than the standard lift ring, it should be a relative easy retrofit. If you don't already have the SS pins to lock the opposite side, you will need those too.
Tom
PS31#111 Cielo Azul
High-Frequency Radio Basics Kathy Barron Seamanship Articles 0 10-14-2000 08:00 PM
High-Frequency Radio Basics Kathy Barron Gear and Maintenance Articles 0 10-14-2000 08:00 PM
High-Frequency Radio Basics Kathy Barron Her Sailnet Articles 0 10-14-2000 08:00 PM
Choosing and Installing an SSB Radio Sue & Larry Gear and Maintenance Articles 0 09-28-2000 08:00 PM
Choosing and Installing an SSB Radio Sue & Larry Cruising Articles 0 09-28-2000 08:00 PM
HTML code is Off
