07-22-2010
Super Fuzzy Moderator
Originally Posted by johnbanfield
We did this last year:
We fitted the pump on the inside of the cupboard under the sink, placing it on the left wall next to the head. I sits just above the moulded ridge, far back enough so that the handle can be left in place and moves between the sink drain and the locker door. We need to push the handle starboard to close the locker door because we have a toilet paper holder there too.
Most of the work was fitting the white plastic sanitation hose. We used hot water to soften it but it was still really hard. Anyone got any tips for next time?
When we redid Raven's hoses we still ended up using boiling (or just past boiling) water. The secret there, seems to be keeping the hose in the water until the last possible moment. I actually stuck the hose into a kettle and left it there while the water boiled then carried kettle and hose to the head. I also tried the Wombet's hair dryer (12v) but it simply did not have enough grunt. I'd be thinking that if you have access to mains power then a good mains voltage hairdryer might just work.
Six months after redoing the hoses the seacock died. I had one of the blokes at the yard help me fit the new one and he simply hit the hose with a heat gun. Crude but effective, though you need to be careful.
