spinnaker pole set up - SailNet Community
post #1 of 4 Old 12-19-2009 Thread Starter
HI all,
Well i have just bought a PSC 37 and sailed it up to cairns.(600nm)
I wished to pole the jib out but was unsure as there are no up haul or downhaul lines, which i was previously use to.
So my question is, How is the pole controlled? Do i use another halyard??
Thanks guys
Gavin
83XT4 is offline
post #2 of 4 Old 12-20-2009
orientalnc2010's Avatar
Hi Gavin,
Congrats on your new 37, you sailed her to Cairns Australia? Where did your journey begin? Usually a whisker pole is used to pole out a jib or genoa. It is adjustable so you can use it with different headsails. The outboard end snaps on the working jib sheet and you could use a staysail halyard to as a pole topping lift.
Since the spinnaker pole is a fixed length you will have limited control over the shape of the jib.
Hope this helps.
Regards,
Steve
PSC 31 #125
Ryoko
Oriental, NC
One of the two happiest days in a sailors life
orientalnc2010 is offline
post #3 of 4 Old 12-21-2009 Thread Starter
Thanks
It is telescopic, so that explains a bit, and using the staysail halyard makes sense as it leads to cockpit
Cool
I bought the boat in bundaberg, just nth of brisbane.
Thanks steve
83XT4 is offline
post #4 of 4 Old 12-21-2009
teejayevans's Avatar
Originally Posted by 83XT4 View Post
Thanks
Cool
Thanks steve
I have 3 lines, the halyard, and a control line lead aft, and a control
line lead forward, through a snap block and back to the cockpit. When
properly adjusted, it should be perpendicular to the mast so the pole
only has compression forces. I have a separate halyard because my
mast had a place to attach a block. The lines don't need to be heavy,
the jib sheet is taking most of the stress, I use 3/8" lines on my 31.
Tom
PS31#111 Cielo Azul
teejayevans is offline
Refining Your Downwind Sails Brian Hancock Gear and Maintenance Articles 0 04-06-2004 08:00 PM
Spinnaker Fundamentals Steve Colgate Learning to Sail Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Seamanship Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Gear and Maintenance Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Racing Articles 0 06-24-2000 08:00 PM
HTML code is Off
