01-02-2010
John,
I'm not an expert on these issues, but while you're waiting for someone more informed to respond, a few comments since I've observed a few things on my '97 34 . . .
Pacific Seacraft installed the flat copper foil HF radio counterpoise and glassed it in around the interior circumference of the hull near the waterline (and I believe also running port - starboard from there down through the bilge over the keel bolts and backup the other side in a couple cases) while it was being manufactured. You can easily see it if you look closely in the bow chain locker or in the propane tank locker. Very few manufacturers do this and it's an example of how Pacific Seacraft has kept blue water cruiser requirements in mind. My assumption is that you'd ground the SSB equipment to the 2" strap coming out from the hull liner behind the breaker panel. I haven't checked into whether it's connected to the DC ground, but I know that's discouraged by some. I'll leave it to the experts to comment on that aspect.
The heavy wires coming off the dynaplate are part of the lightning ground system. These wires run to the forestay, backstay, and shroud chainplates and also to the mast base so that if the mast is struck, the current runs down the standing rigging and mast, and hopefully out the dynaplate into the water. You may want to check to see if there's also a wire running from the dynaplate to a forward keel bolt; I believe PSC may have changed their approach concerning that over time (I've heard) based on consultation with Nigel Calder. Again you can easily see the connection of these wires to the chainplates in the stem/stern lockers.
My boat did not come with the optional cutter rig hardware installed, so I purchased the inner forestay tackplate from PSC. When I install it, I plan to also run heavy wire from that forward to the heavy wire connection point on the forestay chainplate.
Regards,
MC1
