encapsulated keel - Page 2 - SailNet Community
post #11 of 14 Old 01-08-2010
I had a little rock gouge in the keel a few years ago. The yard filled and bottom painted - a year later it needed repair again. I ground it out smooth, filled with West mixed with fairing. Then I covered with 2-part Interlux epoxy barrier before bottom painting. Three years later it's still perfectly smooth and coated with bottom paint.
Steve
PSC 31 #84
Talisman
stevemac00 is offline
post #12 of 14 Old 01-09-2010
orientalnc2010's Avatar
I would like to add my 2 cents to the subject. If any portions of the keel is flaking off or loose then grind down to bare metal and follow west epoxy instructions for applying their product to the keel. Quick summary, once down to bare metal wash immediately with acetone and apply unthickened epoxy to the metal and work in with a wire brush. While this coating is still green, set off but not cured, apply fairing compound. Use epoxy thickened with micro balloons. Its just a powder that thickens the epoxy into a paste that is easily sanded smooth. Then you can apply a barrier coat.
I had great success with this method on a sabre 34. Portions of the keel had failing fairing, instead of spot repairing I took her completely down to bare metal. 6 years later when I sold her the keel still looked great.
Regards,
Steve
PSC 31 #125
Ryoko
Oriental, NC
One of the two happiest days in a sailors life
orientalnc2010 is offline
post #13 of 14 Old 01-09-2010
One of None
deniseO30's Avatar
this is a
is an oday " encapsulated keel" it's lead within fiberglass.
My last project!
deniseO30 is offline
post #14 of 14 Old 01-09-2010
tager's Avatar
If the PO thought it was encapsulated, but it wasn't, odds are he never checked the keel bolts!
tager is offline
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 09:32 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Keel Bolt Concerns Don Casey Gear and Maintenance Articles 0 10-12-2003 08:00 PM
Iron Keels mogul11 Boat Review and Purchase Forum 3 07-08-2002 03:36 AM
HTML code is Off
