Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
  #1
Old 02-13-2010
MC1 MC1 is offline
MC1 is on a distinguished road
Sealing 3" hole in PSC deck near mast
As it's quite chili up here in the Great Lakes in the Spring / Fall, I've picked up a Dickinson propane cabin heater. I'll be installing it on the port side bulkhead of a PSC '34, hear the mast. The installation calls for cutting a 3" hole through the deck for the air intake / exhaust pipe.
How should I deal with sealing the deck for a hole this large, with an epoxy plug similar to what would be done for bolt holes, or is there is a better approach? Should I drill a slightly larger hole (maybe 3.25"), epoxy, then drill the 3" hole in the epoxy?
Any other lessons learned from those who've installed a cabin propane heater?
  #2
Old 02-13-2010
xsboats's Avatar
xsboats is on a distinguished road
After cutting out the hole with a hole saw, remove the core adjacent to the hole to a distance outward from the hole equal to the thickness of the core. Paint the resulting groove with epoxy and then fill it with epoxy thickened to the consistency of peanut butter. Duct tape the edge of the hole to prevent the thickened epoxy from sagging. Sand when the fill has cured. [remove tape first]. Finish by glassing edge of cutout with a layer of finish cloth , like 2" 10 oz. fiberglass tape. Trim excess glass. Install bedded fitting.
  #3
Old 02-13-2010
MC1 MC1 is offline
Thanks for the info. Xsboats, appreciated.
You may post attachments
You may edit your posts
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 11:06 AM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 08:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
SEO by vBSEO 3.6.1
