04-05-2010
Originally Posted by Norstar
Completed installation of the Raymarine SR50 weather module to work with our C80 display. Installation was straightforward and system works as advertised. Hardest part was figuring out where to mount the receiver which is larger then I anticipated. Mounted in cabinet just forward of nav table on starboard side back to back with nav area. System takes awhile to load initial data but when powering up but has lots of useful weather info at your disposal. Sirius subscription around $360 annual. (less then $1 day)
John S
PSC 34 # 201
Norstar
I've mounted the SR50 receiver in the locker under the PSC 34 nav table seat, along with a Raymarine Autopilot controller. I mounted both onto a piece of "marine lumber" (1/4" polymer sheet), bolted that to the inside of the locker, and left enough slack in the wiring so I can remove the entire setup from the locker to get at fuses / wire connections /etc. if need be in the future.
It's too bad there's not quite enough room to mount all this directly in the electronics area to starboard of the nav table. I hate to use regular locker space for this, but I guess it's a common enough problem. PSC 34s are a little stingy with the storage space, so I hate to lose any.
