Bronze Portlight "Wing nut" - SailNet Community
post #1 of 7 Old 03-16-2010 Thread Starter
Dear folks,
In repairing the corroded, leaking bronze oval portlights in our 1985 PSC 37 one of the latches that pull the portlights closed (do they have a name?) was clearly badly frozen up. Despite days of treatment with PB Blaster, heat, and gentle tapping, in snapped right off when I applied torque.
I was able to manufacture a new bolt out of a regular bronze cap screw but all attempts to extract the broken off bit of bolt from the "wing nut" (see picture below) have failed. Before I get into serious brazing and re-tapping, I wonder if anyone has one of these puppies laying around or knows of a source?
Many thanks, Jay
PSC 37 Kenlanu
BirdBrain333 is offline
post #2 of 7 Old 03-16-2010
xsboats's Avatar
If you are looking for wingnuts, then you've come to the right forum! Seriously though, have you tried contacting Pacific Seacraft? Although they probably do not stock what you need, they should be able to tell you whose ports they install in their boats. You may be able to buy the replacement hatch dog and studs from ABI , if they are the same size .
xsboats is offline
post #3 of 7 Old 03-16-2010
Capnblu's Avatar
I'd heat the bronze, melt on a bit of wax, and while hot take it off.
Why, why, why?
I Don't Know! I Don't Know!
Capnblu is offline
post #4 of 7 Old 03-17-2010
Jay,
I believe Whitewater Marine (the same place that sells the gaskets, see other thread) in Florida has them.
Paul
discoverer37 is offline
post #5 of 7 Old 03-17-2010
Jay,
I just called them (Tel: (800) 572-8871 I talked to Curtis) and yes, they do have them at $25 each.
Paul
post #6 of 7 Old 03-17-2010
Jay,
that price ($25) includes the stud and hinge pin. The nut is not sold separately.
My ports use a more conventional looking wing nut (with actual wings), which are not available. What thread size did you use on the bolt you fabricated the stud out off?
Paul
post #7 of 7 Old 03-18-2010 Thread Starter
Thanks
Thanks, everyone. This is very helpful and will save me MANY hours trying to salvage the old one.
Jay
What type of bronze? Newport41 Gear & Maintenance 2 11-04-2009 12:04 AM
Seacocks- Marelon or Bronze bidet Gear & Maintenance 2 11-03-2004 12:07 PM
Resolving Hatch and Portlight Problems Tom Wood Gear and Maintenance Articles 0 03-17-2003 07:00 PM
Cape Dory Bronze Portlights WLJarrell General Discussion (sailing related) 5 11-26-2001 08:28 AM
Testing the condition of bronze turnbuckles Sloop23_417 Gear & Maintenance 2 05-04-2001 03:38 PM
HTML code is Off
