Moving from freshwater to saltwater - SailNet Community
post #1 of 14 Old 03-22-2010 Thread Starter
Our PSC 31 has always been a freshwater boat and I'm trying to learn what needs to be done before launch to migrate to salt. Are there any other zincs in addition to teardrop and maxprop (Yanmar?)? Do you guys spray the zinc and bronze with the Petit barnacle paint? What about transducers? All suggestions appreciated.
Steve
PSC 31 #84
Talisman
stevemac00 is offline
post #2 of 14 Old 03-22-2010
FSMike's Avatar
Steve -
Heat exchanger zinc?
Never paint a zinc.
We always paint our shafts, props, etc. but some people say not to.
Never paint the area where the zinc will be attached (shaft etc.).
Bottom paint is usually rolled and/or brushed, not sprayed.
Pettit has lots of competition in bottom paint, ask around in the area you will be going to find out what works.
Transducers are a good source of argument. Most say not to paint the depth sounder, some say it doesn't make any difference. We always left it bare until we forgot once and it didn't seem to make any noticeable difference. We always paint the knotmeter, just remember to make sure it spins freely after it's dry and before you launch.
Let's see -- When you install a shaft zinc, make sure the bolt heads are facing in the direction of rotation when the trans is in forward. When you install the shaft zinc, tighten down firmly, tap it with a hammer, then tighten again. You don't want them coming off unnoticed.
Enjoy your new horizons.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #3 of 14 Old 03-23-2010
You may have magnesiums, not zincs. Zincs don't really work in fresh water. The only downside to mag in salt is that it will be gone MUCH faster than a zinc.
The maxprop will be zinc as PYI does not offer a mag for the maxprop.
xort is offline
post #4 of 14 Old 03-23-2010 Thread Starter
The zincs that are on Talisman are the original fifteen years ago - slightly pitted but otherwise in good shape. Still, I thought it best to replace them in case we do make it to salt.
Our bottom paint has always been Micron Extra which should be fine.
What is a shaft zinc? I'm not sure our boat has one.
What about all the bronze thru-hulls? Should the bottom paint be cleaned off these?
Steve
PSC 31 #84
Talisman
post #5 of 14 Old 03-23-2010
Then they are likely zinc, not magnesium. Usually you don't need mags or zincs in fresh water but when you do, you need mag as zinc will not do much.
xort is offline
post #6 of 14 Old 03-23-2010
FSMike's Avatar
A shaft zinc is a two piece circular affair that goes on the shaft. If you have a sail drive that doesn't apply. We paint the through hulls.
Sail Fast Live Slow
FSMike is offline
post #7 of 14 Old 03-23-2010
Moderator
JohnRPollard's Avatar
Aside from switching over to saltwater zincs (as others pointed out, you should have a different type for fresh water) at the shaft and prop, and a possibly a different bottom paint formulation, I can't think of anything else.
There's nothing to do to the bronze thru-hulls -- they should be left unpainted.
JohnRPollard is offline
post #8 of 14 Old 03-23-2010
Zinc Anodes - ZimarĀ® Shaft Zinc Anodes - Inch Sizes: Deep Blue Yacht Supply
It's a zinc collar that goes on your propeller shaft. Comes in sizes to match the diameter of the shaft. I use both a shaft zinc and a prop zinc.
They get replaced every year.
As FS Mike says ..Definitely check the heat exchanger zinc, if you have one,
and any engine zincs?
Welcome to Salt water...and Tides and Currents!
tempest is offline
post #9 of 14 Old 03-23-2010
Moderator
Good point.
However, many of the smaller Yanmars don't have engine/heat exchanger zincs. The 3GM30Fs used in our boats (PSC 31s) don't have them.
post #10 of 14 Old 03-23-2010 Thread Starter
John, do we have a shaft zinc? I can't figure out where there's room.
Steve
PSC 31 #84
Talisman
Water, Precious Water Michael Carr Cruising Articles 0 09-02-2004 08:00 PM
Freshwater vs Saltwater boat; ASA courses NJW3 Boat Review and Purchase Forum 6 09-06-2003 06:42 AM
HTML code is Off
